NethServer Version: NethServer release 7.3.1611 (Final)
Module: httpd-admin
Hi, I can’t access to Admin Web UI, the service fails as follows:
● httpd-admin.service - Server Manager UI httpd instance
Loaded: loaded (/usr/lib/systemd/system/httpd-admin.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since mié 2018-08-22 15:13:13 -03; 3min 48s ago
Docs: https://github.com/NethServer/nethserver-httpd-admin
Process: 32082 ExecStart=/usr/sbin/httpd -f /etc/httpd/admin-conf/httpd.conf -c MaxConnectionsPerChild 12 -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 32082 (code=exited, status=1/FAILURE)
ago 22 15:13:13 muteriver.infoestructura.local systemd[1]: Started Server Manager UI httpd instance.
ago 22 15:13:13 muteriver.infoestructura.local systemd[1]: Starting Server Manager UI httpd instance...
ago 22 15:13:13 muteriver.infoestructura.local httpd[32082]: AH00526: Syntax error on line 87 of /etc/httpd/admin-conf/httpd.conf:
ago 22 15:13:13 muteriver.infoestructura.local httpd[32082]: Invalid command 'php_value', perhaps misspelled or defined by a module not included in the server configuration
ago 22 15:13:13 muteriver.infoestructura.local systemd[1]: httpd-admin.service: main process exited, code=exited, status=1/FAILURE
ago 22 15:13:13 muteriver.infoestructura.local systemd[1]: Unit httpd-admin.service entered failed state.
ago 22 15:13:13 muteriver.infoestructura.local systemd[1]: httpd-admin.service failed.
In line 87 of etc/httpd/admin-conf/httpd.conf I have:
php_value session.save_path /var/cache/nethserver-httpd-admin
Please could you help me to figure it out?
Thanks in advance!
