NethServer Version: Nethserver 7.8.2003 Module: restore backup della configurazione
Ho appena installato l’ultima versione della community di Nethserver 7.8.2003 su macchina virtuale gestita da Proxmox (versione 6.2.6)
Non riesco a fare il restore del backup di configurazione presente sul server attualmente in uso (Nethserver enterprise versione 7.7.1908)
Questo è l’errore che vedo nei log del server:
cockpit-bridge: No entry for terminal type “unknow”
cockpit-bridge: Using dumb terminal server
I just installed the latest version of Nethserver 7.8.2003 community on a virtual machine managed by Proxmox (version 6.2.6)
I can’t restore the configuration backup on the server currently in use (Nethserver enterprise version 7.7.1908)
This is the error I see in the server logs:
cockpit-bridge: No entry for terminal type “unknow”.
perhaps the problem is the difference between the Nethserver community version and the Nethserver Enterprise version. Maybe the repo files need to be changed?
the configuration backup is on an Enterprise version 7.7.1908 and I want to restore it on the virtual machine Nethesis community 7.8.2003 installed on proxmox
No
Users account LDAP, Webtop, File server, Nextcloud, Fail to ban.
from the linux console with the tail -f / var / log / messages command
