Hi i have this scenario host windows can’t resolve file server.
this is the network:
fw01 (nethserver firewall) >> 192.168.100.1
dc01(samba ad domain controller) >> 192.168.100.2
srv01(file server) >> 192.168.100.4
gestionale(client windows) >> 192.168.100.5
gestionale,srv01 has join the dc.
The problem is gestionale can’t resove srv01 with the name.
I check on the DC01 if DNS Server is listen on 53 and this is the output but as i remember the dns service not using UDP instead TCP?
For non-capisc’-boot speaking persons…
Gateway is 192.168.100.1
DNS server is only 192.168.100.2, DC01 or the nethserver installation which is also bridging the DC container 192,168.100.3.
I’m not currently on a DC installation to run analogue tests, but nslookup on windows seems the tool to verify if the resolution is working as intended.
I’ am correct if I assume that srv01 had joined to DC?
Please, @Denis_Pollini, english speaking screenshots.
I am Italian and I can understand what’s written there, but not all users of this community are.
Glad to see a Firefox fellow.
ok but i need to change the language of nethserver and windows for screenshoot is more tricky cause i need to change to english and back to italian continuosly.
But it it’s need i try to put in english version screenshoot
yes firefox best browser btw
Worth asking.
Anyway:
1: you can check on DC01 if DNS is reporting the host for srv01
2: you can use your DNS tools for Windows to look into NDSC, for finding out if the AD container held up by samba knows more about DNS records.
