Problem OpenVPN Nethsecurity
Hi all
I’ve install a fresh nethsecurity, i configure lan,wan and i’m able to navigate to internet.
But the problem i noticed is that when i go to add a OpenVPN RoadWarrior and i click on the “Create Button” nothing appened, it seems the button when i click on it, nothing change, this is the screeshoot:
we are about to release a fix for this issue, stay tuned :slight_smile:
Image version 23.05.4-ns.1.2.0-34-gedb15f4b should fix the issue
Hi when your release this image for download?
I check now on the system and there is not update available.
Thanks.
If you have an active subscription you’ll have to wait for the next stable release.
If you don’t, the update is already available: keep in mind that it’s not a stable update yet.
