Problem obtaning Let's Encrypt certificate
NethServer Version: 7.6
Module: Certificate
I’m obtaining this error when I try to request a certificate… how can I solve? It seems a sudo permission error
[Domini]
Questa lezione dovrebbe essere stata impartita dall’amministratore di sistema locale. Solitamente equivale a: #1) Rispettare la privacy degli altri #2) Pensare prima di digitare #3) Da grandi poteri derivano grandi responsabilità sudo: nessun tty presente e nessun programma di richiesta password specificato
How did you do the request? Via the server manager or the cli?
Translation:
This lesson should have been given by the local system administrator. Usually it is equivalent to: # 1) Respect the privacy of others # 2) Think before typing # 3) From big powers derive big responsibility sudo: no tty present and no password request program specified
server manager
There must have been some customization I guess.
I don’t have any customization… who is the user that execute the command for certificate installation?
Maybe this helps:
https://wiki.nethserver.org/doku.php?id=developer:letsencrypt&s[]=encrypt
http://docs.nethserver.org/projects/nethserver-devel/en/v7/nethserver-letsencrypt.html?highlight=encrypt
I do this command and it works:
yum --enablerepo=nethserver-testing install nethserver-base nethserver-httpd nethserver-letsencrypt
config setprop pki LetsEncrypt enabled
I think it was missing nethserver-letsencrypt package.
Thank you.
