NethServer Version: NethServer release 7.7.1908
Module: NextCloud
Good morning
Now i have update NethServer and i have relese 7.7.1908
and now error is
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please includethe technical details below in your report.
More details can be found in the server log.
my nexcloud configurations is
config show nextcloud
TrustedDomains=cloudoe.mail01.it
VirtualHost=cloudoe.mail01.it
Wellknown=disabled
[root@mail01 ~]# systemctl status -l mariadb mysqld rh-php72-php-fpm
â mariadb.service - MariaDB database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; disabled; vendor preset: disabled)
Active: inactive (dead)
â mysqld.service - MariaDB database server
Loaded: loaded (/usr/lib/systemd/system/mysqld.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2020-04-22 16:47:59 CEST; 36min ago
Process: 1485 ExecStartPost=/usr/libexec/mariadb-wait-ready $MAINPID (code=exited, status=0/SUCCESS)
Process: 1309 ExecStartPre=/usr/libexec/mariadb-prepare-db-dir %n (code=exited, status=0/SUCCESS)
Main PID: 1484 (mysqld_safe)
CGroup: /system.slice/mysqld.service
ââ1484 /bin/sh /usr/bin/mysqld_safe --basedir=/usr
ââ1707 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/log/mariadb/mariadb.log --pid-file=/var/run/mariadb/mariadb.pid --socket=/var/lib/mysql/mysql.sock
Apr 22 16:47:41 mail01.oeonline.it systemd[1]: Starting MariaDB database serverâŚ
Apr 22 16:47:42 mail01.oeonline.it mariadb-prepare-db-dir[1309]: Database MariaDB is probably initialized in /var/lib/mysql already, nothing is done.
Apr 22 16:47:42 mail01.oeonline.it mariadb-prepare-db-dir[1309]: If this is not the case, make sure the /var/lib/mysql is empty before running mariadb-prepare-db-dir.
Apr 22 16:47:44 mail01.oeonline.it mysqld_safe[1484]: 200422 16:47:44 mysqld_safe Logging to â/var/log/mariadb/mariadb.logâ.
Apr 22 16:47:44 mail01.oeonline.it mysqld_safe[1484]: 200422 16:47:44 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
Apr 22 16:47:59 mail01.oeonline.it systemd[1]: Started MariaDB database server.
â rh-php72-php-fpm.service - The PHP FastCGI Process Manager
Loaded: loaded (/usr/lib/systemd/system/rh-php72-php-fpm.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/rh-php72-php-fpm.service.d
âânethserver-rh-php72-php-fpm.conf
Active: active (running) since Wed 2020-04-22 16:47:57 CEST; 36min ago
Main PID: 1330 (php-fpm)
Status: âProcesses active: 0, idle: 11, Requests: 107, slow: 0, Traffic: 0req/secâ
CGroup: /system.slice/rh-php72-php-fpm.service
ââ1330 php-fpm: master process (/etc/opt/rh/rh-php72/php-fpm.conf
ââ2462 php-fpm: pool nethserver-nextcloud
ââ2463 php-fpm: pool nethserver-nextcloud
ââ2464 php-fpm: pool nethserver-nextcloud
ââ2465 php-fpm: pool nethserver-nextcloud
ââ2466 php-fpm: pool nethserver-nextcloud
ââ2467 php-fpm: pool www
ââ2468 php-fpm: pool www
ââ2469 php-fpm: pool www
ââ2470 php-fpm: pool www
ââ2472 php-fpm: pool www
ââ2750 php-fpm: pool nethserver-nextcloud
Apr 22 16:47:41 mail01.oeonline.it systemd[1]: Starting The PHP FastCGI Process ManagerâŚ
Apr 22 16:47:57 mail01.oeonline.it systemd[1]: Started The PHP FastCGI Process Manager.
[root@mail01 ~]#
sudo -u apache scl enable rh-php72 â php -dmemory_limit=512M /usr/share/nextcloud/occ maintenance:mode
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
Maintenance mode is currently disabled
sudo -u apache scl enable rh-php72 â php -dmemory_limit=512M /usr/share/nextcloud/occ app:list
Enabled:
- accessibility: 1.2.0
- activity: 2.9.1
- cloud_federation_api: 0.2.0
- comments: 1.6.0
- dav: 1.9.2
- federatedfilesharing: 1.6.0
- federation: 1.6.0
- files: 1.11.0
- files_external: 1.7.0
- files_pdfviewer: 1.5.0
- files_rightclick: 0.15.1
- files_sharing: 1.8.0
- files_trashbin: 1.6.0
- files_versions: 1.9.0
- files_videoplayer: 1.5.0
- firstrunwizard: 2.5.0
- logreader: 2.1.0
- lookup_server_connector: 1.4.0
- nextcloud_announcements: 1.5.0
- notifications: 2.4.1
- oauth2: 1.4.2
- password_policy: 1.6.0
- privacy: 1.0.0
- provisioning_api: 1.6.0
- recommendations: 0.4.0
- serverinfo: 1.6.0
- settings: true
- sharebymail: 1.6.0
- support: 1.0.0
- survey_client: 1.4.0
- systemtags: 1.6.0
- theming: 1.7.0
- twofactor_backupcodes: 1.5.0
- twofactor_totp: 3.0.1
- updatenotification: 1.6.0
- user_ldap: 1.6.0
- viewer: 1.1.0
- workflowengine: 1.6.0
Disabled:- admin_audit
- calendar
- contacts
- encryption
- passwords
- photos
- text
end error in log is
{âreqIdâ:âXqBbk0UsT1jU-L8GlVgHcgAAAAMâ,âlevelâ:3,âtimeâ:â2020-04-22T14:58:27+00:00â,âremoteAddrâ:â123.456.789.111â,âuserâ:âââ,âappâ:âcoreâ,âmethodâ:âGETâ,âurlâ:â/remote.php/dav/â,âmessageâ:"Service unavailable ",âuserAgentâ:âApache-HttpClient/4.5.3 (Java/1.8.0_242)â,âversionâ:â16.0.5.1â}
{âreqIdâ:âXqBbk0UsT1jU-L8GlVgHcgAAAAMâ,âlevelâ:3,âtimeâ:â2020-04-22T14:58:27+00:00â,âremoteAddrâ:â123.456.789.111â,âuserâ:âââ,âappâ:âcoreâ,âmethodâ:âGETâ,âurlâ:â/remote.php/dav/â,âmessageâ:{âExceptionâ:âDoctrine\DBAL\Exception\TableNotFoundExceptionâ,âMessageâ:âAn exception occurred while executing âSELECT
filecache.fileid,storage,path,path_hash,filecache.parent,name,mimetype,mimepart,size,mtime,storage_mtime,encrypted,etag,permissions,checksum,metadata_etag,creation_time,upload_timeFROMoc_filecachefilecacheLEFT JOINoc_filecache_extendedfeONfilecache.fileid=fe.fileidWHERE (storage= ?) AND (path_hash= ?)â with params [2, "dedc35aaaa2ffd41fa701e78f1ab84e9"]:\n\nSQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud.oc_filecache_extendedâ doesnât existâ,âCodeâ:0,âTraceâ:[{âfileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.phpâ,âlineâ:169,âfunctionâ:âconvertExceptionâ,âclassâ:âDoctrine\DBAL\Driver\AbstractMySQLDriverâ,âtypeâ:â->â,âargsâ:[âAn exception occurred while executing âSELECTfilecache.fileid,storage,path,path_hash,filecache.parent,name,mimetype,mimepart,size,mtime,storage_mtime,encrypted,etag,permissions,checksum,metadata_etag,creation_time,upload_timeFROMoc_filecachefilecacheLEFT JOINoc_filecache_extendedfeONfilecache.fileid=fe.fileidWHERE (storage= ?) AND (path_hash= ?)â with params [2, "dedc35aaaa2ffd41fa701e78f1ab84e9"]:\n\nSQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud.oc_filecache_extendedâ doesnât existâ,{âerrorInfoâ:[â42S02â,1146,âTable ânextcloud.oc_filecache_extendedâ doesnât existâ],âclassâ:âDoctrine\DBAL\Driver\PDOExceptionâ}]},{âfileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.phpâ,âlineâ:145,âfunctionâ:âwrapExceptionâ,âclassâ:âDoctrine\DBAL\DBALExceptionâ,âtypeâ:â::â,âargsâ:[{âclassâ:âDoctrine\DBAL\Driver\PDOMySql\Driverâ},{âerrorInfoâ:[â42S02â,1146,âTable ânextcloud.oc_filecache_extendedâ doesnât existâ],âclassâ:âDoctrine\DBAL\Driver\PDOExceptionâ},âAn exception occurred while executing âSELECTfilecache.fileid,storage,path,path_hash,filecache.parent,name,mimetype,mimepart,size,mtime,storage_mtime,encrypted,etag,permissions,checksum,metadata_etag,creation_time,upload_timeFROMoc_filecachefilecacheLEFT JOINoc_filecache_extendedfeONfilecache.fileid=fe.fileidWHERE (storage= ?) AND (path_hash= ?)â with params [2, "dedc35aaaa2ffd41fa701e78f1ab84e9"]:\n\nSQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud.oc_filecache_extendedâ doesnât existâ]},{âfileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.phpâ,âlineâ:911,âfunctionâ:âdriverExceptionDuringQueryâ,âclassâ:âDoctrine\DBAL\DBALExceptionâ,âtypeâ:â::â,âargsâ:[{âclassâ:âDoctrine\DBAL\Driver\PDOMySql\Driverâ},{âerrorInfoâ:[â42S02â,1146,âTable ânextcloud.oc_filecache_extendedâ doesnât existâ],âclassâ:âDoctrine\DBAL\Driver\PDOExceptionâ},âSELECTfilecache.fileid,storage,path,path_hash,filecache.parent,name,mimetype,mimepart,size,mtime,storage_mtime,encrypted,etag,permissions,checksum,metadata_etag,creation_time,upload_timeFROMoc_filecachefilecacheLEFT JOINoc_filecache_extendedfeONfilecache.fileid=fe.fileidWHERE (storage= ?) AND (path_hash= ?)â,{â1â:2,â2â:âdedc35aaaa2ffd41fa701e78f1ab84e9â}]},{âfileâ:â/usr/share/nextcloud/lib/private/DB/Connection.phpâ,âlineâ:199,âfunctionâ:âexecuteQueryâ,âclassâ:âDoctrine\DBAL\Connectionâ,âtypeâ:â->â,âargsâ:[âSELECTfilecache.fileid,storage,path,path_hash,filecache.parent,name,mimetype,mimepart,size,mtime,storage_mtime,encrypted,etag,permissions,checksum,metadata_etag,creation_time,upload_timeFROMoc_filecachefilecacheLEFT JOINoc_filecache_extendedfeONfilecache.fileid=fe.fileidWHERE (storage= ?) AND (path_hash= ?)â,[2,âdedc35aaaa2ffd41fa701e78f1ab84e9â],[1,2],null]},{âfileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.phpâ,âlineâ:200,âfunctionâ:âexecuteQueryâ,âclassâ:âOC\DB\Connectionâ,âtypeâ:â->â,âargsâ:[âSELECTfilecache.fileid,storage,path,path_hash,filecache.parent,name,mimetype,mimepart,size,mtime,storage_mtime,encrypted,etag,permissions,checksum,metadata_etag,creation_time,upload_timeFROMoc_filecachefilecacheLEFT JOINoc_filecache_extendedfeONfilecache.fileid=fe.fileidWHERE (storage= :dcValue1) AND (path_hash= :dcValue2)â,{âdcValue1â:2,âdcValue2â:âdedc35aaaa2ffd41fa701e78f1ab84e9â},{âdcValue1â:1,âdcValue2â:2}]},{âfileâ:â/usr/share/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.phpâ,âlineâ:215,âfunctionâ:âexecuteâ,âclassâ:âDoctrine\DBAL\Query\QueryBuilderâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Cache/Cache.phpâ,âlineâ:153,âfunctionâ:âexecuteâ,âclassâ:âOC\DB\QueryBuilder\QueryBuilderâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/Files/View.phpâ,âlineâ:1329,âfunctionâ:âgetâ,âclassâ:âOC\Files\Cache\Cacheâ,âtypeâ:â->â,âargsâ:[âappdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/View.phpâ,âlineâ:1384,âfunctionâ:âgetCacheEntryâ,âclassâ:âOC\Files\Viewâ,âtypeâ:â->â,âargsâ:[{âcacheâ:{âclassâ:âOC\Files\Cache\Cacheâ},âscannerâ:null,âwatcherâ:null,âpropagatorâ:null,âupdaterâ:null,âclassâ:âOCA\Files_Trashbin\Storageâ},âappdata_ocxqw1407wha/js/coreâ,â/appdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Node/Root.phpâ,âlineâ:199,âfunctionâ:âgetFileInfoâ,âclassâ:âOC\Files\Viewâ,âtypeâ:â->â,âargsâ:[â/appdata_ocxqw1407wha/js/coreâ]},{âfunctionâ:âgetâ,âclassâ:âOC\Files\Node\Rootâ,âtypeâ:â->â,âargsâ:[â/appdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Node/LazyRoot.phpâ,âlineâ:65,âfunctionâ:âcall_user_func_arrayâ,âargsâ:[[{âclassâ:âOC\Files\Node\Rootâ},âgetâ],[âappdata_ocxqw1407wha/js/coreâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Node/LazyRoot.phpâ,âlineâ:142,âfunctionâ:â__callâ,âclassâ:âOC\Files\Node\LazyRootâ,âtypeâ:â->â,âargsâ:[âgetâ,[âappdata_ocxqw1407wha/js/coreâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/AppData/AppData.phpâ,âlineâ:143,âfunctionâ:âgetâ,âclassâ:âOC\Files\Node\LazyRootâ,âtypeâ:â->â,âargsâ:[âappdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/JSCombiner.phpâ,âlineâ:96,âfunctionâ:âgetFolderâ,âclassâ:âOC\Files\AppData\AppDataâ,âtypeâ:â->â,âargsâ:[âcoreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/JSResourceLocator.phpâ,âlineâ:115,âfunctionâ:âprocessâ,âclassâ:âOC\Template\JSCombinerâ,âtypeâ:â->â,âargsâ:[â/usr/share/nextcloudâ,âcore/js/merged-template-prepend.jsonâ,âcoreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/JSResourceLocator.phpâ,âlineâ:71,âfunctionâ:âcacheAndAppendCombineJsonIfExistâ,âclassâ:âOC\Template\JSResourceLocatorâ,âtypeâ:â->â,âargsâ:[â/usr/share/nextcloudâ,âcore/js/merged-template-prepend.jsonâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/ResourceLocator.phpâ,âlineâ:78,âfunctionâ:âdoFindâ,âclassâ:âOC\Template\JSResourceLocatorâ,âtypeâ:â->â,âargsâ:[âjs/merged-template-prependâ]},{âfileâ:â/usr/share/nextcloud/lib/private/TemplateLayout.phpâ,âlineâ:346,âfunctionâ:âfindâ,âclassâ:âOC\Template\ResourceLocatorâ,âtypeâ:â->â,âargsâ:[[âcore/js/dist/mainâ,âjs/merged-template-prependâ,âsearch/js/searchâ,âcore/l10n/enâ,âsearch/l10n/enâ,âsearch/js/searchproviderâ,âjs/files/fileinfoâ,âjs/files/clientâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/TemplateLayout.phpâ,âlineâ:174,âfunctionâ:âfindJavascriptFilesâ,âclassâ:âOC\TemplateLayoutâ,âtypeâ:â::â,âargsâ:[[âcore/js/dist/mainâ,âjs/merged-template-prependâ,âsearch/js/searchâ,âcore/l10n/enâ,âsearch/l10n/enâ,âsearch/js/searchproviderâ,âjs/files/fileinfoâ,âjs/files/clientâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/legacy/template.phpâ,âlineâ:184,âfunctionâ:â__constructâ,âclassâ:âOC\TemplateLayoutâ,âtypeâ:â->â,âargsâ:[âerrorâ,ââ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/Base.phpâ,âlineâ:132,âfunctionâ:âfetchPageâ,âclassâ:âOC_Templateâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/legacy/template.phpâ,âlineâ:300,âfunctionâ:âprintPageâ,âclassâ:âOC\Template\Baseâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/remote.phpâ,âlineâ:82,âfunctionâ:âprintErrorPageâ,âclassâ:âOC_Templateâ,âtypeâ:â::â,âargsâ:[âService unavailableâ,ââ,503]},{âfileâ:â/usr/share/nextcloud/remote.phpâ,âlineâ:168,âfunctionâ:âhandleExceptionâ,âargsâ:[{âclassâ:âRemoteExceptionâ}]}],âFileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.phpâ,âLineâ:42,âPreviousâ:{âExceptionâ:âDoctrine\DBAL\Driver\PDOExceptionâ,âMessageâ:âSQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud.oc_filecache_extendedâ doesnât existâ,âCodeâ:â42S02â,âTraceâ:[{âfileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.phpâ,âlineâ:903,âfunctionâ:âexecuteâ,âclassâ:âDoctrine\DBAL\Driver\PDOStatementâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/DB/Connection.phpâ,âlineâ:199,âfunctionâ:âexecuteQueryâ,âclassâ:âDoctrine\DBAL\Connectionâ,âtypeâ:â->â,âargsâ:[âSELECTfilecache.fileid,storage,path,path_hash,filecache.parent,name,mimetype,mimepart,size,mtime,storage_mtime,encrypted,etag,permissions,checksum,metadata_etag,creation_time,upload_timeFROMoc_filecachefilecacheLEFT JOINoc_filecache_extendedfeONfilecache.fileid=fe.fileidWHERE (storage= ?) AND (path_hash= ?)â,[2,âdedc35aaaa2ffd41fa701e78f1ab84e9â],[1,2],null]},{âfileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.phpâ,âlineâ:200,âfunctionâ:âexecuteQueryâ,âclassâ:âOC\DB\Connectionâ,âtypeâ:â->â,âargsâ:[âSELECTfilecache.fileid,storage,path,path_hash,filecache.parent,name,mimetype,mimepart,size,mtime,storage_mtime,encrypted,etag,permissions,checksum,metadata_etag,creation_time,upload_timeFROMoc_filecachefilecacheLEFT JOINoc_filecache_extendedfeONfilecache.fileid=fe.fileidWHERE (storage= :dcValue1) AND (path_hash= :dcValue2)â,{âdcValue1â:2,âdcValue2â:âdedc35aaaa2ffd41fa701e78f1ab84e9â},{âdcValue1â:1,âdcValue2â:2}]},{âfileâ:â/usr/share/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.phpâ,âlineâ:215,âfunctionâ:âexecuteâ,âclassâ:âDoctrine\DBAL\Query\QueryBuilderâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Cache/Cache.phpâ,âlineâ:153,âfunctionâ:âexecuteâ,âclassâ:âOC\DB\QueryBuilder\QueryBuilderâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/Files/View.phpâ,âlineâ:1329,âfunctionâ:âgetâ,âclassâ:âOC\Files\Cache\Cacheâ,âtypeâ:â->â,âargsâ:[âappdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/View.phpâ,âlineâ:1384,âfunctionâ:âgetCacheEntryâ,âclassâ:âOC\Files\Viewâ,âtypeâ:â->â,âargsâ:[{âcacheâ:{âclassâ:âOC\Files\Cache\Cacheâ},âscannerâ:null,âwatcherâ:null,âpropagatorâ:null,âupdaterâ:null,âclassâ:âOCA\Files_Trashbin\Storageâ},âappdata_ocxqw1407wha/js/coreâ,â/appdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Node/Root.phpâ,âlineâ:199,âfunctionâ:âgetFileInfoâ,âclassâ:âOC\Files\Viewâ,âtypeâ:â->â,âargsâ:[â/appdata_ocxqw1407wha/js/coreâ]},{âfunctionâ:âgetâ,âclassâ:âOC\Files\Node\Rootâ,âtypeâ:â->â,âargsâ:[â/appdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Node/LazyRoot.phpâ,âlineâ:65,âfunctionâ:âcall_user_func_arrayâ,âargsâ:[[{âclassâ:âOC\Files\Node\Rootâ},âgetâ],[âappdata_ocxqw1407wha/js/coreâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Node/LazyRoot.phpâ,âlineâ:142,âfunctionâ:â__callâ,âclassâ:âOC\Files\Node\LazyRootâ,âtypeâ:â->â,âargsâ:[âgetâ,[âappdata_ocxqw1407wha/js/coreâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/AppData/AppData.phpâ,âlineâ:143,âfunctionâ:âgetâ,âclassâ:âOC\Files\Node\LazyRootâ,âtypeâ:â->â,âargsâ:[âappdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/JSCombiner.phpâ,âlineâ:96,âfunctionâ:âgetFolderâ,âclassâ:âOC\Files\AppData\AppDataâ,âtypeâ:â->â,âargsâ:[âcoreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/JSResourceLocator.phpâ,âlineâ:115,âfunctionâ:âprocessâ,âclassâ:âOC\Template\JSCombinerâ,âtypeâ:â->â,âargsâ:[â/usr/share/nextcloudâ,âcore/js/merged-template-prepend.jsonâ,âcoreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/JSResourceLocator.phpâ,âlineâ:71,âfunctionâ:âcacheAndAppendCombineJsonIfExistâ,âclassâ:âOC\Template\JSResourceLocatorâ,âtypeâ:â->â,âargsâ:[â/usr/share/nextcloudâ,âcore/js/merged-template-prepend.jsonâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/ResourceLocator.phpâ,âlineâ:78,âfunctionâ:âdoFindâ,âclassâ:âOC\Template\JSResourceLocatorâ,âtypeâ:â->â,âargsâ:[âjs/merged-template-prependâ]},{âfileâ:â/usr/share/nextcloud/lib/private/TemplateLayout.phpâ,âlineâ:346,âfunctionâ:âfindâ,âclassâ:âOC\Template\ResourceLocatorâ,âtypeâ:â->â,âargsâ:[[âcore/js/dist/mainâ,âjs/merged-template-prependâ,âsearch/js/searchâ,âcore/l10n/enâ,âsearch/l10n/enâ,âsearch/js/searchproviderâ,âjs/files/fileinfoâ,âjs/files/clientâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/TemplateLayout.phpâ,âlineâ:174,âfunctionâ:âfindJavascriptFilesâ,âclassâ:âOC\TemplateLayoutâ,âtypeâ:â::â,âargsâ:[[âcore/js/dist/mainâ,âjs/merged-template-prependâ,âsearch/js/searchâ,âcore/l10n/enâ,âsearch/l10n/enâ,âsearch/js/searchproviderâ,âjs/files/fileinfoâ,âjs/files/clientâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/legacy/template.phpâ,âlineâ:184,âfunctionâ:â__constructâ,âclassâ:âOC\TemplateLayoutâ,âtypeâ:â->â,âargsâ:[âerrorâ,ââ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/Base.phpâ,âlineâ:132,âfunctionâ:âfetchPageâ,âclassâ:âOC_Templateâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/legacy/template.phpâ,âlineâ:300,âfunctionâ:âprintPageâ,âclassâ:âOC\Template\Baseâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/remote.phpâ,âlineâ:82,âfunctionâ:âprintErrorPageâ,âclassâ:âOC_Templateâ,âtypeâ:â::â,âargsâ:[âService unavailableâ,ââ,503]},{âfileâ:â/usr/share/nextcloud/remote.phpâ,âlineâ:168,âfunctionâ:âhandleExceptionâ,âargsâ:[{âclassâ:âRemoteExceptionâ}]}],âFileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.phpâ,âLineâ:119,âPreviousâ:{âExceptionâ:âPDOExceptionâ,âMessageâ:âSQLSTATE[42S02]: Base table or view not found: 1146 Table ânextcloud.oc_filecache_extendedâ doesnât existâ,âCodeâ:â42S02â,âTraceâ:[{âfileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.phpâ,âlineâ:117,âfunctionâ:âexecuteâ,âclassâ:âPDOStatementâ,âtypeâ:â->â,âargsâ:[null]},{âfileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.phpâ,âlineâ:903,âfunctionâ:âexecuteâ,âclassâ:âDoctrine\DBAL\Driver\PDOStatementâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/DB/Connection.phpâ,âlineâ:199,âfunctionâ:âexecuteQueryâ,âclassâ:âDoctrine\DBAL\Connectionâ,âtypeâ:â->â,âargsâ:[âSELECTfilecache.fileid,storage,path,path_hash,filecache.parent,name,mimetype,mimepart,size,mtime,storage_mtime,encrypted,etag,permissions,checksum,metadata_etag,creation_time,upload_timeFROMoc_filecachefilecacheLEFT JOINoc_filecache_extendedfeONfilecache.fileid=fe.fileidWHERE (storage= ?) AND (path_hash= ?)â,[2,âdedc35aaaa2ffd41fa701e78f1ab84e9â],[1,2],null]},{âfileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.phpâ,âlineâ:200,âfunctionâ:âexecuteQueryâ,âclassâ:âOC\DB\Connectionâ,âtypeâ:â->â,âargsâ:[âSELECTfilecache.fileid,storage,path,path_hash,filecache.parent,name,mimetype,mimepart,size,mtime,storage_mtime,encrypted,etag,permissions,checksum,metadata_etag,creation_time,upload_timeFROMoc_filecachefilecacheLEFT JOINoc_filecache_extendedfeONfilecache.fileid=fe.fileidWHERE (storage= :dcValue1) AND (path_hash= :dcValue2)â,{âdcValue1â:2,âdcValue2â:âdedc35aaaa2ffd41fa701e78f1ab84e9â},{âdcValue1â:1,âdcValue2â:2}]},{âfileâ:â/usr/share/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.phpâ,âlineâ:215,âfunctionâ:âexecuteâ,âclassâ:âDoctrine\DBAL\Query\QueryBuilderâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Cache/Cache.phpâ,âlineâ:153,âfunctionâ:âexecuteâ,âclassâ:âOC\DB\QueryBuilder\QueryBuilderâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/Files/View.phpâ,âlineâ:1329,âfunctionâ:âgetâ,âclassâ:âOC\Files\Cache\Cacheâ,âtypeâ:â->â,âargsâ:[âappdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/View.phpâ,âlineâ:1384,âfunctionâ:âgetCacheEntryâ,âclassâ:âOC\Files\Viewâ,âtypeâ:â->â,âargsâ:[{âcacheâ:{âclassâ:âOC\Files\Cache\Cacheâ},âscannerâ:null,âwatcherâ:null,âpropagatorâ:null,âupdaterâ:null,âclassâ:âOCA\Files_Trashbin\Storageâ},âappdata_ocxqw1407wha/js/coreâ,â/appdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Node/Root.phpâ,âlineâ:199,âfunctionâ:âgetFileInfoâ,âclassâ:âOC\Files\Viewâ,âtypeâ:â->â,âargsâ:[â/appdata_ocxqw1407wha/js/coreâ]},{âfunctionâ:âgetâ,âclassâ:âOC\Files\Node\Rootâ,âtypeâ:â->â,âargsâ:[â/appdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Node/LazyRoot.phpâ,âlineâ:65,âfunctionâ:âcall_user_func_arrayâ,âargsâ:[[{âclassâ:âOC\Files\Node\Rootâ},âgetâ],[âappdata_ocxqw1407wha/js/coreâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/Node/LazyRoot.phpâ,âlineâ:142,âfunctionâ:â__callâ,âclassâ:âOC\Files\Node\LazyRootâ,âtypeâ:â->â,âargsâ:[âgetâ,[âappdata_ocxqw1407wha/js/coreâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/Files/AppData/AppData.phpâ,âlineâ:143,âfunctionâ:âgetâ,âclassâ:âOC\Files\Node\LazyRootâ,âtypeâ:â->â,âargsâ:[âappdata_ocxqw1407wha/js/coreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/JSCombiner.phpâ,âlineâ:96,âfunctionâ:âgetFolderâ,âclassâ:âOC\Files\AppData\AppDataâ,âtypeâ:â->â,âargsâ:[âcoreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/JSResourceLocator.phpâ,âlineâ:115,âfunctionâ:âprocessâ,âclassâ:âOC\Template\JSCombinerâ,âtypeâ:â->â,âargsâ:[â/usr/share/nextcloudâ,âcore/js/merged-template-prepend.jsonâ,âcoreâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/JSResourceLocator.phpâ,âlineâ:71,âfunctionâ:âcacheAndAppendCombineJsonIfExistâ,âclassâ:âOC\Template\JSResourceLocatorâ,âtypeâ:â->â,âargsâ:[â/usr/share/nextcloudâ,âcore/js/merged-template-prepend.jsonâ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/ResourceLocator.phpâ,âlineâ:78,âfunctionâ:âdoFindâ,âclassâ:âOC\Template\JSResourceLocatorâ,âtypeâ:â->â,âargsâ:[âjs/merged-template-prependâ]},{âfileâ:â/usr/share/nextcloud/lib/private/TemplateLayout.phpâ,âlineâ:346,âfunctionâ:âfindâ,âclassâ:âOC\Template\ResourceLocatorâ,âtypeâ:â->â,âargsâ:[[âcore/js/dist/mainâ,âjs/merged-template-prependâ,âsearch/js/searchâ,âcore/l10n/enâ,âsearch/l10n/enâ,âsearch/js/searchproviderâ,âjs/files/fileinfoâ,âjs/files/clientâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/TemplateLayout.phpâ,âlineâ:174,âfunctionâ:âfindJavascriptFilesâ,âclassâ:âOC\TemplateLayoutâ,âtypeâ:â::â,âargsâ:[[âcore/js/dist/mainâ,âjs/merged-template-prependâ,âsearch/js/searchâ,âcore/l10n/enâ,âsearch/l10n/enâ,âsearch/js/searchproviderâ,âjs/files/fileinfoâ,âjs/files/clientâ]]},{âfileâ:â/usr/share/nextcloud/lib/private/legacy/template.phpâ,âlineâ:184,âfunctionâ:â__constructâ,âclassâ:âOC\TemplateLayoutâ,âtypeâ:â->â,âargsâ:[âerrorâ,ââ]},{âfileâ:â/usr/share/nextcloud/lib/private/Template/Base.phpâ,âlineâ:132,âfunctionâ:âfetchPageâ,âclassâ:âOC_Templateâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/lib/private/legacy/template.phpâ,âlineâ:300,âfunctionâ:âprintPageâ,âclassâ:âOC\Template\Baseâ,âtypeâ:â->â,âargsâ:},{âfileâ:â/usr/share/nextcloud/remote.phpâ,âlineâ:82,âfunctionâ:âprintErrorPageâ,âclassâ:âOC_Templateâ,âtypeâ:â::â,âargsâ:[âService unavailableâ,ââ,503]},{âfileâ:â/usr/share/nextcloud/remote.phpâ,âlineâ:168,âfunctionâ:âhandleExceptionâ,âargsâ:[{âclassâ:âRemoteExceptionâ}]}],âFileâ:â/usr/share/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.phpâ,âLineâ:117}},âCustomMessageâ:âââ},âuserAgentâ:âApache-HttpClient/4.5.3 (Java/1.8.0_242)â,âversionâ:â16.0.5.1â
