Hi all i’m try to do “migrate in place” on a nethserver7 only have firewall module running on a virtual machine on proxmox.
Everything goes fine until the vm reboot and is stuck on this screen:
Vm Settings:
Any ideas?
Thanks
We received some reports of the same problem, but we never reproduced it.
We think it may be related to PVE disk cache configuration (see Disk Cache wiki documentation | Proxmox Support Forum).
Could you try direct sync tr write through?
Hi @filippo_carletti
Unfortunaly on this specific installation i resolve by create new vm for nethsecurity install it and then import che configuration file from ns7.
If i encountered same problem on another customer i try it.
Thanks
