I can’t install the Mr Markuz repo.
Hi @Ensys_Technology and welcome to NethServer Community.
It’s working here. Can you download it with a browser?
Here is some more info about the repo and even guacamole…
I can download from the browser. I also installed the rpm locally but if I try to install the package I’m getting an ssl error.
yum install -y --enablerepo=mrmarkuz nethserver-guacamole
Sorry I’m not in front of PC now and can’t check. Maybe just try http instead of https?
As a workaround please download the needed modules and install locally. I’m going to check that asap…
I can’t reproduce.
These are working from here:
yum install https://mrmarkuz.dynu.net/mirror/mrmarkuz/7/noarch/nethserver-mrmarkuz-0.0.1-4.ns7.noarch.rpm
yum install nethsever-guacamole --enablerepo=mrmarkuz
yum install https://mrmarkuz.dynu.net/mirror/devtest/nethserver-guacamole-0.0.1-1.ns7.noarch.rpm
I have problems with SSL cert on mrmarkuz.goip.de but no time now, need to solve later…
It does not work with http than with https. Always the same error.
Is it possible to download and install locally?
I have already downloaded and installed the two packages. But when installing the guacamole package it gives me an SSL error while checking for dependencies.
I solved! Unbeknownst to me, there was a transparent proxy that filtered access to the repo. Thanks a lot and sorry.
