Problem installing NS8 on Centos 9 Stream
I get the following
Generating api-server password:
Generating node password:
AUTH failed: WRONGPASS invalid username-password pair or user is disabled.
And finally this
6b10617c164b209a23c16b06f342feb357d149a95078412c7627edba1a886fd6
<7>extract-ui ghcr.io/nethserver/traefik:2.2.3
Extracting container filesystem ui to /var/lib/nethserver/cluster/ui/apps/traefik1
ui/index.html
5871f7a394133d01f1449b6ac7ad5742b73346bca58f1b6c70e11b73bdb977c6
Assertion failed
  File "/var/lib/nethserver/cluster/actions/add-module/50update", line 182, in <module>
    agent.assert_exp(add_module_result['exit_code'] == 0)
Equally on Debian getting the error
Set kernel parameters:
/var/lib/nethserver/node/install-core.sh: line 39: sysctl: command not found
Create the api-server user:
/var/lib/nethserver/node/install-core.sh: line 43: useradd: command not found
Forced to add the following
should this be the case for debian?
Just curious, why would you want to install NS8 on an unsupported OS?
According to this, its supported
System requirements — NS8 documentation (nethserver.org)
Equally, we are deploying build and testing servesr
I stand corrected.
ps. However, I seem to remember discussions where only rocky linux was the officially supported OS. I can’t find it atm, that is the issue with threads and discussions, way too many of them in too many places/tags. Hence I prefer a wiki and up to date official documentation.
Look at traefik1 App in the Logs page: any other information?
Maybe uninstall.sh/install.sh is faster!
