Do not set up local delivery
As for monitoring you need to set up samba, http, mysql , because there are a lot of depencies. Feel free to ask any question.
i have some problem in installing teamviewer on Qubes OS…i’m creating a VM with window to install TW…i will MP the login data
i can give also you root access to the server if it can help
S97nethserver-samba-sam-conf #35 (exit status 256)
S98nethserver-samba-group-sync #38 (exit status 256)
less /var/log/messages
Mar 1 21:01:27 mail esmith::event[30401]: Unix group locals already mapped to SID S-1-5-21-1826104982-2660851038-3095404102-513
Mar 1 21:01:27 mail esmith::event[30401]: Failed to map unix group `locals` to samba rid 513 at /etc/e-smith/events/runlevel-adjust/S97neths
erver-samba-sam-conf line 155.
Mar 1 21:01:27 mail esmith::event[30401]: Unix group domadmins already mapped to SID S-1-5-21-1826104982-2660851038-3095404102-512
Mar 1 21:01:27 mail esmith::event[30401]: Failed to map unix group `domadmins` to samba rid 512 at /etc/e-smith/events/runlevel-adjust/S97ne
thserver-samba-sam-conf line 155.
Mar 1 21:01:28 mail esmith::event[30401]: Unix group domcomputers already mapped to SID S-1-5-21-1826104982-2660851038-3095404102-515
Mar 1 21:01:28 mail esmith::event[30401]: Failed to map unix group `domcomputers` to samba rid 515 at /etc/e-smith/events/runlevel-adjust/S9
7nethserver-samba-sam-conf line 155.
Mar 1 21:01:28 mail esmith::event[30401]: Unix group domguests already mapped to SID S-1-5-21-1826104982-2660851038-3095404102-514
Mar 1 21:01:28 mail esmith::event[30401]: Failed to map unix group `domguests` to samba rid 514 at /etc/e-smith/events/runlevel-adjust/S97ne
Mar 1 21:01:28 mail esmith::event[30401]: Could not find name domadmins
Mar 1 21:01:28 mail esmith::event[30401]: Failed to add privileges to domadmins group at /etc/e-smith/events/runlevel-adjust/S97nethserver-s
amba-sam-conf line 170.
Mar 1 21:01:28 mail esmith::event[30401]: Action: /etc/e-smith/events/runlevel-adjust/S97nethserver-samba-sam-conf FAILED: 1 [0.601495]
Mar 1 21:01:28 mail esmith::event[30401]: Action: /etc/e-smith/events/runlevel-adjust/S98nethserver-mail-server-init-system-users SUCCESS [0
.020761]
Mar 1 21:01:28 mail esmith::event[30401]: Mapping group domadmins failed with NT_STATUS_GROUP_EXISTS
Mar 1 21:01:28 mail esmith::event[30401]: [ERROR] Failed to add group `domadmins` in SAM database!
Please do not use the alpha release for production!
Moreover, I’m working on the samba and mail server packages for 7 and the mail configuration will be changed deeply, so I think tests are not required now.
The main point was OVH DNS configuration.We have added MX record to the subdomain.
Next point was changed Hostname, thus, SambaSID changed but not for every CN (I have changed through LDAP)
Another point VPN, by default OpenVPN service in DB was enabled, thus system init neither systemd have no any targets. (it was fixed and committed to GIT)
it isn’t a production environment i plan to switch my vps and dedicated server with mailserver and owncloud into one unique VPS (with Nethserver). For personal purposes.
I wanted to try NS7 but I think I will return to NS6
even if just for you, as long as you store on that machine valuable data (photos, email, files etc) it is a “production” server… so my sentence is still valid
alpha releases are there just to test and broke them
