I have a problem during a update.
When I run yum update, after the check, I have this return:
--> Running transaction check
---> Package ncurses-libs.i686 0:5.7-4.20090207.el6 will be installed
---> Package samba-winbind-clients.i686 0:3.6.23-33.el6 will be installed
--> Processing Dependency: samba-winbind = 3.6.23-33.el6 for package: samba-winbind-clients-3.6.23-33.el6.i686
Error: Package: samba-winbind-clients-3.6.23-33.el6.i686 (base)
Requires: samba-winbind = 3.6.23-33.el6
Removing: samba-winbind-3.6.23-25.el6_7.x86_64 (@centos-updates)
samba-winbind = 3.6.23-25.el6_7
Updated By: samba-winbind-3.6.23-35.el6_8.x86_64 (nethserver-updates)
samba-winbind = 3.6.23-35.el6_8
Available: samba-winbind-3.6.23-20.el6.x86_64 (centos-base)
samba-winbind = 3.6.23-20.el6
Available: samba-winbind-3.6.23-21.el6_7.x86_64 (centos-updates)
samba-winbind = 3.6.23-21.el6_7
Available: samba-winbind-3.6.23-24.el6_7.x86_64 (centos-updates)
samba-winbind = 3.6.23-24.el6_7
Available: samba-winbind-3.6.23-30.el6_7.x86_64 (centos-updates)
samba-winbind = 3.6.23-30.el6_7
Available: samba-winbind-3.6.23-33.el6.x86_64 (base)
Available: samba4-winbind-4.0.0-66.el6_6.rc4.x86_64 (centos-base)
samba-winbind = 4.0.0-66.el6_6.rc4
Available: samba4-winbind-4.0.0-67.el6_7.rc4.x86_64 (centos-updates)
samba-winbind = 4.0.0-67.el6_7.rc4
Available: samba4-winbind-4.0.0-68.el6_7.rc4.x86_64 (centos-updates)
samba-winbind = 4.0.0-68.el6_7.rc4
Available: samba4-winbind-4.2.10-6.el6_7.x86_64 (base)
samba-winbind = 4.2.10-6.el6_7
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Before, I was make a downgrade of SAMBA for compatibility from Nethserver with machines with W7 and WXp. Now I have all computers with w10.
I think this problem happen because I have done this downgrade, and now I can`t do the update (and install new packages that I need)
I already do a cache clean in Yum and use the --skip-broken option.
Someone can help?
Nethserver 6.7
