Hi All.
I Have a problem with som send mail.
I have a server with SOGo, mail are in html format.
When the user send an email, if the recipient have Outlook, the mail have this format :
I have now 3 servers has same Problem.
All have SOGo v5.0.0
If i use Sogo to send with caracter é à 'è the problem appear.
Same problem with SOGo and attachement file. The file was write on the email with crypted text. ANd no attachement file.
On 1 server i have apply by yum update.
For one week that was OK. but Yesterday, i receive a mail with the problem.
I will try to apply the 2 others.
It’s very strange.
I guess it is a compiled software so I think you cannot find it as is, anyways on linux, install mlocate, then update the database by updatedb and search by locate myFile
