Printer Server Not Work - Error Filter Failed
NethServer Version 7.8.2
Module: Printer Server
Hello, I use Nethserver 7.8.2 and installed the CUPS print server, I added an HP 1020 printer it was added but when I send a test print I get the message from Filer Failed.
Please have a look at the logs and post them. Don’t forget the
/var/log/messages
with which protocol you connected?
-=This error happens on the CUPs web interface when I send a print test page
Found this thread: https://serverfault.com/questions/602523/cups-is-not-printing-with-filter-failed-message-how-to-get-more-info
Possible cause: incompatibility of Cups filters with installed version of ghostscript.
Try to downgrade either Cups Filters or upgrade Ghostscript
