PPTP OutGoing connection
**NethServer Version: NethServer release 7.2.1511 (beta2)
Kernel
3.10.0-327.36.1.el7.x86_64
**Module: “Firewall Rules” i think…
So, i have an external PPTP Server Running ClearOS 7
I need one of my servers inside a NethServer Network to acess this PPTP server.
So the ports, i need to “open” to the server to acess it with PPTP are:
I tried OpenVPN, but my timeclock (the device i need to acess) won´t “ping” or acess when i have the openVpn conection set up. Maybe becouse i can´t use Brigde connection. :-/
Just made a rule from my server(the one that should connect to the pptp server) to any destiny with any service… and it just worked… :stuck_out_tongue:
Good stuff!
Thanks anyway! :slight_smile:
