Is it possible for 2 separate modules installed within Nethserver8 either in the same node or separate nodes, but within the same cluster, to be able to communicate together, as if within the same network, and share some resources, like the folder Structure or use the mount points inside the module containers as an FTP source or directory, without going over the general internet.
Could a kind of tunnel for this case be achieved currently?
