Help to update packages with translations of portuguese brazilian.
I am and others people translate on transifex, but dont effect on packages updates on nehtserver.
Help with this issue!
Thanks.
Thanks.
Please Rafael make an example of what is not working (i.e. the page which is missing a specific label): I’ll investigate it!
Never had any problem with the Brazilian language.
Hello,
One example on cockpit
Info on transifex, translated 11 days ago and last package update 2 days ago
Cockpit on Nethserver updated
Thanks!
I think the cockpit exibit language portugueses portugal and dont portuguese brazilian
Because on transifex Users & Groups dont have translations to portuguese pt
The possible solution a separate portuguese pt and portuguese pt-br on different packages
Automatic updates of nethserver-lang run every month. Latest automatic release occurred 2 days ago, 2019-09-18 16:04 CEST
Does it fix the problem?
Dont fix, the nethserver heve updated with this package, the problem is the cockpit dont difference a portuguese pt and portugues pt-br
It seems the build attempted to retrieve the right resource here,
https://travis-ci.org/NethServer/nethserver-lang/jobs/586607631#L3251
…however there were no commited file changes… since 4 months!?
https://github.com/NethServer/nethserver-lang/tree/master/ui
Need more time to investigate the reason. However I already verified that if /usr/share/cockpit/nethserver/i18n/language.pt_BR.json.gz gets modified the changes are picked up by the Cockpit UI, so the problem is in the automated RPM build process.
Let’s see how it goes by adding a -a flag to tx pull…
Build results will be pushed to nethserver-updates repo soon: check it out!
https://travis-ci.org/NethServer/nethserver-lang/builds/587570093
Ok I got it now…
The automated build does not commit changes under ui/
I’m going to fix it next week!
Thank You!!
Fix released in nethserver-lang-pt-1.3.0-10.ns7.noarch.rpm
Confirmed!!! Thanks!!!
