NethServer Version: 7
Module: your_module
I have installed nethserver on centos 7, after installation via ssh, I was told process complete.
when I went to my_ip_address it seemed to work ok
when I went to my_ip_address:980 page did not load
Module: your_module
Check if something on this thread helps:
Do you get any specific error message on that page, in your browser Developer Tools, or in the logs?
I changed from my current provider, and got a vps from arubacloud and it worked well.
generally speaking, it seems nethserver does not work well with openvz systems
Hi @oneitonitram,
Thanks for reply. Could you mark your answer as solution please?
