POP3 connector randomly freezing
Hello everyone.
I have a problem with a server where several pop3 connectors are active to deliver mail internally. Everything works without problems, but randomly some connector freezes and to restart it I have to deactivate it and reactivate it.
What could I control?
Thank you
Hi and welcome to NethServer Community,
are there errors in /var/log/messages or /var/log/maillog ?
Maybe it helps to increase the fetch interval?
Which mail provider do you use? Is it about GMail?
I recommend to use NethServer as mail server instead of using pop connector/smarthost if possible. Check out the wiki and the documentation for more details.
Related topic:
Hi Markus and thanks for the welcome.
In the log files I do not notice any particular problem.
I tried to increase the fetch interval to 10 minutes, but I did not solve the problem.
The provider is a local provider (etics.it).
I searched the web regarding etics and getmail…but without success.
Maybe try another protocol (IMAP, POP3) to get the mails?
Here is some documentation about how getmail is implemented.
