ThomasM
(Thomas M. Ball)
January 11, 2019, 2:33pm
1
NethServer Version: 7.6.1810
Installed Plex.
Can’t access the webserver on :32400.
After stopping shorewall, I can access the server.
So I created a port forwarding:
18=pf
Description=Plex
Dst=32400
DstHost=host;diener
Log=none
Proto=tcp
Src=32400
status=enabled
but it is not working, what do I do wrong?
Thomas
Try this from command line:
config set fw_plex service status enabled TCPPorts 32400 access green
signal-event firewall-adjust
signal-event runlevel-adjust
EddieA
(Eddie Atherton)
January 12, 2019, 12:07am
3
ThomasM:
Installed Plex.
Where. On NS or a server on the internal network.
From where. An internal server or externally.
Cheers.
ThomasM
(Thomas M. Ball)
January 12, 2019, 2:41pm
5
Thanks for the reply, but saitobenkei solved my problem…
