capote
(Marko)
February 13, 2022, 3:03pm
1
NethServer Version: 7.9
Module: Piler
Hi, Installing and importing mails is very easy. Now I make my frist steps within and want to administrate piler.
Mi first question: If I want to activate a retention rule, I got a hint:
I believe that’s not the right one for Nethserver/Centos7
whats the right group? apache?
is it the right path for /etc/init.d/rc.pilier? Ther is no one…
If I save visudo I got:
Warning: /etc/sudoers.d/55_nsapi_perms:25 Cmnd_Alias “NSAPI_NETHSERVER_PILER” referenced but not defined
Warning: /etc/sudoers.d/55_nsapi_perms:26 Cmnd_Alias “NSAPI_NETHSERVER_PILER” referenced but not defined
best regrads, Marko
stephdl
(Stéphane de Labrusse)
February 13, 2022, 4:51pm
2
Could you point me the full documentation, since piler runs inside a pull of containers I am quite sure what you read is not relevant
mrmarkuz
(Markus Neuberger)
February 13, 2022, 5:32pm
3
I could reproduce. After executing visudo, saving and exiting I got the same errors.
A file like /etc/sudoers.d/50_nsapi_nethserver_piler is missing, it should include the defintions:
# nsapi_nethserver_piler
Cmnd_Alias NSAPI_NETHSERVER_PILER = \
/usr/libexec/nethserver/api/nethserver-piler/read
Defaults!NSAPI_NETHSERVER_PILER !requiretty
@stephdl I found the same issue in nethserver-sympa.
cronlabspl
(cronlabspl)
February 13, 2022, 7:34pm
4
@mrmarkuz simple as: sudo touch /etc/sudoers.d/50_nsapi_nethserver_piler
mrmarkuz
(Markus Neuberger)
February 13, 2022, 7:37pm
5
No, you need the content too, simply creating the file is not enough.
capote
(Marko)
February 13, 2022, 10:19pm
6
thank you. I added the file and modified the sudoers file. But the info box comes again:
mrmarkuz
(Markus Neuberger)
February 13, 2022, 10:27pm
7
The info box is a separate issue. I guess it’s not necessary to add something manually except the retention rule is not working. Piler is running in docker environment so local file changes won’t have an effect.
stephdl
February 15, 2022, 8:18pm
9
fixed for piler and sympa
capote
(Marko)
February 27, 2022, 8:42pm
10
Now I try to eliminate unwanted mails, like spam.
To do this, I have configured a retention policy with spam=yes and “Days to retain” = 1 day.
But the spam mail still exists. What have I misunderstood?
Note: When I try to save the rule via “Apply changes”, the above error message repeats itself.
stephdl
February 27, 2022, 9:11pm
11
Check module:piler [NethServer Wiki]
It seems you tried to set it by the user interface of piler. Do I am right ?
The error in the sudoers is relative to the container and not from nethserver itself
capote
(Marko)
February 27, 2022, 9:51pm
12
yes
This is what I did, without any knowledge in this regard
and what practical consequence does this have?
stephdl
February 28, 2022, 7:00pm
13
could you make some screenshots please on what you did to get the errors, I think we need to check if they are not an update of the containers and if no then do a bug report to @jutso
stephdl
March 1, 2022, 3:27am
15
I saw there is an Update. We install 1.3.10 and 1.3.11 is available
