PIler 1.0.0 configuration issues
Installed it via software center and cofigured it with FQDN and mailserver and default retention days.
Created symlink /home/piler1/.config/systemd/user/default.target.wants/piler.service → /home/piler1/.config/systemd/user/piler.service.
Error: no container with name or ID "piler-app" found: no such container
Assertion failed
  File "/home/piler1/.config/actions/configure-module/90add-relay-rule", line 42, in <module>
    agent.assert_exp(response['exit_code'] == 0)
In settings the chosen mail domain is gone. It can beselected again, but the save button will stay grayed out.
HTH
cannot reproduce
Does the mailserver was configured (first domain set)
well if the server is not configured we cannot save the form (it is expected)
Yes, there is 1 mail domain configured up and running
When I select the one and only mail domain from the drop down, the save button stays greyed out.
What browser and version are you using?
Chrome
The first boot is quite long , we have a countdown of 60 seconds and maybe you hit it so you got a miconfigured instance
With my server I recall to wait 15 seconds…
Can you try again and check the time to install…the log could be also a clue because we print the time after each seconds IIRC
Anyway we need the log to understand
After the installation
journalctl > dump
  • Removed instance 1
  • Reinstalled instance 2
  • Waited until last log entry appeared in the log (see below), and waited 30 secs extra
  • Went to software center, instance, "not configured’ → configure
  • Enter FQDN, certificate and https, retention default
  • Same issue
  • Waited another 120 secs and tried to save again
  • Same issue
Created symlink /home/piler2/.config/systemd/user/default.target.wants/piler.service → /home/piler2/.config/systemd/user/piler.service.
Assertion failed
  File "/home/piler2/.config/actions/configure-module/90add-relay-rule", line 42, in <module>
Copy to clipboard
Show less
2024-06-01T10:54:30+02:00 [1:piler2:agent@piler2] Writing manifest to image destination
2024-06-01T10:54:30+02:00 [1:piler2:agent@piler2] 9200bd86da810533901767e7211ee0accd4d5a762792e6f4d7bff4c5210eb910
2024-06-01T10:54:30+02:00 [1:piler2:agent@piler2] Trying to pull docker.io/library/memcached:1.6.26-alpine...
2024-06-01T10:54:32+02:00 [1:piler2:agent@piler2] Getting image source signatures
2024-06-01T10:54:32+02:00 [1:piler2:agent@piler2] Copying blob sha256:3d2a65ada68aba9def3ee64975e1d20608c30fbb31babe05bf0a052fd5b9e631
2024-06-01T10:54:32+02:00 [1:piler2:agent@piler2] Copying blob sha256:bf4ca62cc3e912d97d5818cdb2c21bfd6ef17fb2a46bb9ff37ef80b46aeb7579
2024-06-01T10:54:32+02:00 [1:piler2:agent@piler2] Copying blob sha256:8b997d515984ace5a566abec5f367a569bf51dcb5c860f5f1868154d8d61ca54
2024-06-01T10:54:32+02:00 [1:piler2:agent@piler2] Copying blob sha256:873fcbe9681f30840a11a64dc6ef9dfef47f40b1181e1c876969a13e35b6f5b4
2024-06-01T10:54:32+02:00 [1:piler2:agent@piler2] Copying blob sha256:7e9ac090217572c7ea3a76702db6866b9c0c35dd85d2a2bad5a50ca438050b67
2024-06-01T10:54:32+02:00 [1:piler2:agent@piler2] Copying blob sha256:4abcf20661432fb2d719aaf90656f55c287f8ca915dc1c92ec14ff61e67fbaf8
2024-06-01T10:54:32+02:00 [1:piler2:agent@piler2] Copying config sha256:b686fb4e394c572a1980b134344b94d4673fcf49dd492838d7ee6a22c4c73466
2024-06-01T10:54:32+02:00 [1:piler2:agent@piler2] Writing manifest to image destination
2024-06-01T10:54:33+02:00 [1:piler2:agent@piler2] b686fb4e394c572a1980b134344b94d4673fcf49dd492838d7ee6a22c4c73466
2024-06-01T10:54:33+02:00 [1:piler2:agent@piler2] task/module/piler2/33de0342-5cbb-4a0e-ba3d-249d4207e4d1: create-module/10selfadm_role is starting
2024-06-01T10:54:33+02:00 [1:piler2:agent@piler2] 1
2024-06-01T10:54:33+02:00 [1:piler2:agent@piler2] task/module/piler2/33de0342-5cbb-4a0e-ba3d-249d4207e4d1: create-module/10set_env is starting
2024-06-01T10:54:33+02:00 [1:piler2:agent@piler2] task/module/piler2/33de0342-5cbb-4a0e-ba3d-249d4207e4d1: action "create-module" status is "completed" (0) at step 10set_env
2024-06-01T10:56:36+02:00 [1:piler2:systemd] Starting Mark boot as successful...
2024-06-01T10:56:36+02:00 [1:piler2:systemd] Finished Mark boot as successful.
After second configure attempt https://pastebin.com/hTfG0YCf
ps. Maybe not related but I do not have the option relay configured in the mail module. Never touched it.
Is Mail updated to version 1.4.0+?
You have the testing switch enabled. Is it wanted? Testing releases have more bugs than you expect :wink:
Apart from warning you for the testing switch, the Mail version is good.
Nope, not at all, but living on the digital edge brings out the unexpected in an early stage :slight_smile: This is not a prod node
