PHPVirtualBox No Remote Console after Update
NethServer Version: 7.6.1810 (final)
Module: VirtualBox & PhpVirtualBox
Hi all
There was a software update for VirtualBox 5.2 5.2.24_128163_el7-1. I installed update and how I have no remote console in phpvirtualbox it shows port 19000-19100 with a red line through it.
yep since it is a beta, I did not make a migrate fragment
change the port
config setprop phpvirtualbox TCPPortsRDP 19000-19100
signal-event phpvirtualbox-save
I tried that but no go … I am thinking that it may have to do with the EXTPACK ??
Since virtualbox is updated. How do I update the EXTPACK?
Ok thats what it was … The EXTPACK all looks good …
I’ll have to remember to do that…
to update the extension pack, do
signal-event virtualbox-update
