I’ve installed phpmyadmin from @stephdl repository but I can’t open the site.
Forbidden
You don't have permission to access /phpmyadmin on this server.
I restarted httpd service, but same error.
I think I have to change the rights of the site to apache:apache, but I can’t find it at the server.
Can somebody give me some tips?
Thanks in advance
[Wed Jan 16 11:19:18.558405 2019] [ssl:warn] [pid 3427] AH01909: RSA certificate configured for localhost.localdomain:443 does NOT include an ID which matches the server name
[Wed Jan 16 11:19:18.559040 2019] [ssl:warn] [pid 3427] AH01906: RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
and for error_log
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using localhost.localdomain. Set the 'ServerName' directive globally to suppress this message
[Wed Jan 16 10:10:29.465304 2019] [auth_digest:notice] [pid 4047] AH01757: generating secret for digest authentication ...
[Wed Jan 16 10:10:29.466336 2019] [lbmethod_heartbeat:notice] [pid 4047] AH02282: No slotmem from mod_heartmonitor
[Wed Jan 16 10:10:29.468599 2019] [ssl:warn] [pid 4047] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed Jan 16 10:10:29.490529 2019] [mpm_prefork:notice] [pid 4047] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/5.4.16 configured -- resuming normal operations
[Wed Jan 16 10:10:29.490566 2019] [core:notice] [pid 4047] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Wed Jan 16 10:11:09.943085 2019] [mpm_prefork:notice] [pid 4047] AH00171: Graceful restart requested, doing restart
Both logs have the date of today, but only entries from 16th January.
No, the site you see is at a server of a provider.
My job is to copy this website you see to an internal webserver for presentation without internet connection.
Thanks again Michael
PS: Is it possible to automatically do a link in every vhost directory to reach phpmyadmin with all vhost addresses?
@stephdl, you don’t have to search for it, I looked at error_log again and today I found entries from yesterday, which said, phpmyadmin is only reachable with ssl.
With
