NethServer release 7.6.1810 your_version
PHP your_module
Terrible Problem
Running several Wordpress installations on my nethserver.
I run an yum autoremove which removed all php installations expept 5.x
Wordpress need 6.x something.
I remember that i could choose the php version for each vhost, but that option is gone…
Tried to install php-shl with this instruction: https://wiki.nethserver.org/doku.php?id=php-scl
But when issuing:
yum install nethserver-php-scl --enablerepo=stephdl
i get many dependensy problems
Requires: php70-php-mcrypt
Error: Package: nethserver-php-scl-1.2.7-1.ns7.sdl.x86_64 (stephdl)
Requires: php71-php-opcache
Requires: php72-php-bcmath
Requires: php71-php-soap
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
whats wrong?
Tried the installation several times no success.
I managed to install rh-php70, but i don’t know how to tell my vhosts to use it…
It’s kind of urgend, because my important websites are down…
