Is the phone home system included in NethServer 8?
For NethServer 7 it was great to see the global deployments.
Data are already sent to server but not shown on the map.
It requires a bit of work on the UI side. Does anyone want to try? The code is here: GitHub - NethServer/phonehome-server: Phonehome Server for NethServer 8
I know that @Tbaile took a look to it, but I do not remember how is hard to show also NethServer 8 and NethSecurity 8 installations on the map.
Phonehome got a major overhaul in the backend, however the frontend wouldâve took too much time to implement and has been left a bit there to rot. (weâre still analyzing the data, but with some other tools)
The UI must be rewritten completely due to some nasty calls that the backend makes for compatibility. On top of that I donât like too much the current implementation, Iâd like a more âdata-orientedâ approach, so that everyone can see the general hardware the machines are running on and give the community a more educated guess on whatâs the general usage of both hardware and software is.
Some of the info that can be extracted:
Not going to lie, if Metabase or SuperSet would do the job nicely Iâll probably swap the UI for a dashboard generated with such tools.
With all that said, if you want to contribute to such thing the code is up above and everything is build on top of Laravel, so resources for contributing are all over the place ![]()
I like the global deployment graphics. Is that âeasierâ to impelement as a intermediate step?
Has the GDPR been incorporated in the phone home system, for I can not remember that I needed to give permission to share my server data, even anonymous? Just checking.
I have to rework the API that fetches the info, and itâs a big chore to adapt to the UI and itâs probably going to take a toll on the server for each query (pretending right now that cache doesnât exists), Iâd go my way out of this UI and rewrite the thing (adding insult to injury, itâs unmaintained ad the JS is quite obsolete)
EDIT: Iâm not saying that the big map wonât be there ![]()
Since no data is tied to a physical person and itâs just telemetrics, no GDPR is needed for now (checked with Nick, weâre good), if down the road we face a situation where we need to fetch additional data that ties personal info, the PhoneHome service on the servers will be automatically disabled and youâll be prompt to accept telemetrics usage.
On dev manuals is described how to see which data we send back to the PhoneHome and how to disable it:
Just for arguments sake, an IP address is also considered personal dataâŚ
The only IP that we retrieve is from the HTTP request of the server sending data. Then a GeoIP local database gives us a ISO Code of the country, if successful, the IP is threw away, otherwise no info is logged, just a log signaling that some IPs are not resolved in countries (and the request rejected)
This follows the principle of the link you sent:
Personal data that has been rendered anonymous in such a way that the individual is not or no longer identifiable is no longer considered personal data. For data to be truly anonymised, the anonymisation must be irreversible.
