NethServer Version: 7.8
I joined my windows 10 client to a Nethserver AD Domain.
The Time on the Nethserver is synced via NTP:
The Timezone on the Windows 10 PC is set to Vienna:
How should this be setup?
Usually it should work out of the box.
You may check out the samba time sync docs and compare settings and permissions.
I was able to sync the Windows 10 Client’s time with: net time /set /yes
in a Console, but I needed admin rights…
The question is if and how the client syncs the time with the Nethserver AD ?
I was thinking that this is working. Otherwise it doesn’t make sense to force the client to use the Server for timesync…
Is your time service at the client running?
I think in English it is Windows Time Service, or something similar.
I tried this:
But the client’s Windows-Time-Service starts manually… The clients time is drifting…
I will set the Service to start automatically…
For me it’s set to automatically (delayed start)
And the client is a domain-member? I have to crosscheck this with another windows 10 client…
Yes, the client is a domain-member, but we have a windows 2019 dc.
