PB with timezone in the dashboard and antivirus update
Hello,
The Nethserver is the ntp for the network.
Look at this print screen ( you can see the Mac time, the Server time…
But look on the Dashboard the last update of the virus database/
Weird, what does your freshclam log say?
here the log…
ClamAV update process started at Tue Oct 13 12:15:36 2015
main.cvd is up to date (version: 55, sigs: 2424225, f-level: 60, builder: neo)
Downloading daily-20961.cdiff [100%]
daily.cld updated (version: 20961, sigs: 1608745, f-level: 63, builder: shurley)
bytecode.cvd is up to date (version: 268, sigs: 47, f-level: 63, builder: anvilleg)
Database updated (4033017 signatures) from db.it.clamav.net (IP: 193.206.139.34)
ClamAV update process started at Tue Oct 13 13:18:54 2015
daily.cld is up to date (version: 20961, sigs: 1608745, f-level: 63, builder: shurley)
ClamAV update process started at Tue Oct 13 14:28:33 2015
The freshclam is in localtime, the update happen at 12:15.
The two occurences after (13:18 and 14:28), there’s the verification, but no update…
Today,
In the Dashboard,
Status              Updated
Last update     2015-10-14 16:15
In the freshclam log:
ClamAV update process started at Wed Oct 14 13:15:47 2015
Downloading daily-20965.cdiff [100%]
daily.cld updated (version: 20965, sigs: 1609861, f-level: 63, builder: neo)
Database updated (4034133 signatures) from db.it.clamav.net (IP: 193.206.139.34)
Time on Dashboard refreshes only when you press F5 or update the page.
show > ntpq -p
This field shows mtime of files in /var/lib/clamav/ so it is normal view :slight_smile:
The ntpq -p
# ntpq -p
     remote           refid      st t when poll reach   delay   offset  jitter
-alpha.rueckgr.a 131.188.3.222    2 u  555 1024  377  259.283  -15.601   3.289
+c.ntp.br        200.160.7.186    2 u  230 1024  377  182.908    1.809   7.469
*aprihop.cdknnjl 200.98.196.212   2 u  611 1024  377  153.755   -4.532   4.045
+ec2-54-232-82-2 146.164.48.5     2 u  822 1024  327  131.303   -3.417  17.185
Set right time zone and server :slight_smile:
I sure to have choosen the latin america/brasil/Belem…When I had installed the minimal CentOS.
Not sure I ever gone in the ntp server after the NS installation :smiley:
Edit: @Nas But the Nethserver I as the right date and time… Look at the CLI box on the screen shoot.
The server and the Mac client have the same correct time…
So there is no prob, last update shows last modified files in clamav update dir, time on Dashboard shows those time when page was loaded. It has not dynamic update feature :slight_smile:
No, there’s a mistake here.
When the Dashboard show:
Status              Updated
The right information should be:
Last update     2015-10-14 **13:15**
Between the Dashboard and the freshclam time… There three hours diference.
When I remember look the Dashboard to verify, I was 13:55, perhaps 14:00
To try to be clear:
At the screenshot time, it was 2015-10-13 13:36, when the Dashboard show 2015-10-13 15:15… This date and time not happen yet!!!
The correct time to be shown was 2015-10-13 12:15, not 15:15
/usr/share/nethesis/NethServer/Module/Dashboard/SystemStatus/Antivirus.php
 $fileList = glob('/var/lib/clamav/*.{cvd,cld}', GLOB_BRACE);
        foreach ($fileList as $file) {
            $changeTime = filemtime($file);
            if ($changeTime > $max) {
                $max = $changeTime;
so it shows ls -l /var/lib/clamav/.cld and ls -l /var/lib/clamav/.cvd and calculate max date of the file changes in those dir , so it migth be the situation that after reboot of the server freshclam update bases before time complitely sync.
stat /var/lib/clamav/*.cvd
If you want to see time of the real last freshclam start , you should change file :
Looking at the Disk Usage, I have the same…
Actually, the date and time are 2015-10-14 22:39 ( at the top there only the time )
The update: 2015-10-15 01:38 at the butom…
$timestamp = $stat[‘mtime’];
The same behavior in DUC.php mtime, so my suggestion maybe right
Check the PHP datetime is the same sa the system:
config getprop php DateTimezone
config show TimeZone
Reference:
UTC
TimeZone=America/Belem
You just found the problem :wink:
Align the two values and you’re done.
I guess the right one is “America/Belem”.
 config setprop php DateTimezone America/Belem
 expand-template /etc/php.ini
Reference: http://php.net/manual/en/timezones.america.php
It seem the problem is deeper…
[root@microserver ~]# config setprop php DateTimezone America/Belem
[root@microserver ~]# expand-template /etc/php.ini
[root@microserver ~]# config getprop php DateTimezone
America/Belem
[root@microserver ~]# config show TimeZone
After a reconnection on the webgui, I still have the three hours of difference…
Did I need to reboot?
Finally, I rebooted…
The Dashboard show the “good” time for the antivirus update… :smiley:
But the Disk Usage, still showing the UTC time… :confused:
