Hello Again,
Since last time i managed to get all my apps (close to) connected to the LDAP.
Now i’m on the big one PWM - Password Management based on PWM.
Pwm is looking to the memberof attributes for the admin groups.
I dig a bit and the memberof attribute is not available because the module memberof is not enabled.
I try to do it myself using an ldif with phpldapadmin whitout success.
It’s say that DN does not exist cn=module{0},cn=config [
My referral is :
Any hints about some bestpractises ?
I ask myself also if the change i would made will be still here after major upgrade etc.
