aplima
(António Lima)
1
NethServer Version: NS8
Module: Passbolt
Hello.
I installed Passbolt.
As admin, I can add passwords, users, etc.
I can’t save the email settings for passbolt. I click and it doesn’t save my settings.
Bug? Maybe…
Else I might be doing something wrong, just don’t know what would be.
Thank you
davidep
(Davide Principi)
2
Please check the current Passbolt SMTP settings with:
runagent -m passbolt1 cat smarthost.env
You may try to restart the application from the Applications page to see if it get fixed.
aplima
(António Lima)
3
EMAIL_TRANSPORT_DEFAULT_HOST=
EMAIL_TRANSPORT_DEFAULT_PORT=587
EMAIL_TRANSPORT_DEFAULT_TLS=starttls
EMAIL_DEFAULT_FROM=no-reply@vault.mydomain.tld
PASSBOLT_PLUGINS_SMTP_SETTINGS_SECURITY_SSL_VERIFY_PEER=false
PASSBOLT_PLUGINS_SMTP_SETTINGS_SECURITY_SSL_VERIFY_PEER_NAME=false
PASSBOLT_PLUGINS_SMTP_SETTINGS_SECURITY_SSL_ALLOW_SELF=true
When I open the settings page:
Could not validate the smtp settings
“code”: 400,
“body”: {
“host”: {
“_empty”: “The host name should not be empty.”
davidep
(Davide Principi)
4
SMTP settings are provided by NS8 core and applied automatically to Passbolt. Follow instructions here Email notifications | NethServer 8 documentation
aplima
(António Lima)
5
Thank you Davide Principi.
Worked as you explained.
