Paperless-ngx.env not found
Hello everyone,
i am new here so please forgive my initial mistakes. I have installed nethserver 8 in Proxmox for testing purposes and a problem with paperlessngx.
After updating the app from version 1.2.1 to 1.3.1 via the software center, the program no longer starts. When calling the paperlessngx website, the message “bad gateway” appears.
The only error that i can find in the system log file is:
[1:paperlessngx1:podman] Error: parsing file “/home/paperlessngx1/.config/state/paperless-ngx.env”: open /home/paperlessngx1/.config/state/paperless-ngx.env: no such file or directory
The file does not exist in the /home/paperlessngx1/.config/state directory.
The file /home/paperlessngx1/.config/systemd/user/paperless-server.service contains the following lines:
ExecStart=/usr/bin/podman run
–env-file=%S/state/paperless-ngx.env
What can I do?
Thank you very much
Best regards
Ask @oneitonitram :wink:
Sorry for this let me check the issue and update and get back to you
Hello @Alex69 after updating to the latest version, you need to save the nee configuration under the settings page for the changes to take effect.
Have you done this?
Hello @oneitonitram,
thank you for the advise, but what do you mean about it, the setting page of nethserver or paperlessngx? Where i can find it?
Sorry for my stupid questions and the translation service!
@kemboielvis22 @LayLow
thank you! :wink:
Okay, sorry, i’ to quickly
@oneitonitram
you are right, klick on “Save configuration” under Paperlessngx - preferences solved the problem!
many thanks to all!
Best regards!
