Packet loss over bond
Hi, new fresh install on a physical box with 4 ports, 2 GbE and 2 10GbE:
eth0: wan1
eth1: wan2
eth2+eth3: bond 802.3ad LACP.
I’m experiencing packet losso between vlans.
i have also tried assigning ip at the lag and the switches in vlan 1.
10.10.0.254 → nethsecurity lag
10.10.0.253 → switch
no packet loss on the wan from outside, or from vpn to all lan interfaces on firewall side.
What can it be? is it supported to have vlan over a bond?
Thanks
Is there a high CPU load? It could lead to packet drops.
You can check with Netdata or on CLI using top
this is a period of 2 hours:
the usage is very very low, the firewall is only doing routing, no ispection or ips enable for the moment.
Thanks
