hello to all I need to access from the outside of owncloud (nethserver 6.8)
no problem to turn on https firewall to nethserver but since I have to add the trusted domains where I find the exact folder owncloud
thank you
thank you
@m_farlotta default:
/var/www/html/owncloud/config
within that dir you’ll edit config.php, it’ll be obvious
thanks for reply
