(sorry for my bad english)
but… owncloud don’t work with personal directory of the user?
it’s possibile, in a nethserver like domain controller, see the personal directory throught owncloud?
Access samba user home through owncloud? Usually the Z: windows drive.
It’s possible. Enabled the External storage app and add a storage selecting Username as share.
where can i found this menu?
Take a look at the App panel and follow Filippo’s suggestion
ok… same question…
where is “app panel” menù? what is the italian name?
on the top left
Owncloud menu!
me again
i have only this:
i have only this:
You should ne logged in as owncloud admin
not as normal user.
No @gecco ! ![]()
Try admin with password Nethesis,1234
Don’t worry it was the same for me first time(s) ![]()
ownCloud has is own admin account.
thanks a lot
after only a week my problem is solved
A post was split to a new topic: Can’t see my mounted shares on android app
