OpenVpn Tunnel Clients don't see each other
NethServer Version: NethServer 7.9.2009 Enterprise
Module: Tunnel OVPN
Hello to everyone and thanks in andvace for welcome :slight_smile:
I recently opted for the Nethserver solution in the company connecting 9 client vpn tunnels to a vpn tunnel server " star center" for a question of querying data from a software.
The clients and the “star center” are able to exchange data ( i can ping their subnets) but from a client to another client is not possible (example: from subnet .60 i can’t ping subnet .61 etc but i can ping only “star center” from tunnel client).
This is a scheme of the network (I apologize for my sketch drawn)Ăą
I appreciate any suggestions to allow communication between tunnel clients.
Is there something I can do from the “star center”?
Thank so much
@mastgen
Hi Gennaro
And welcome to the NethServer Community!
If you want clients to be able to “see” each other, you’ll have to edit your Roadwarrior Config, and add in this (Under advanced):
Hope this helps!
Hi Andy and thanks for response!
The type of connection i am using is Tunnel OVPN.
To make you better understand this is my server and client side configuration:
Nethserver Tunnel Client Side (one of 9)
Name: name of connection
Remote Host: public address star center
Port: my tunnel vpn port
Topology: Subnet
Authentication: Certificate
Certificate: The certificate with private key
Remote Network: The local network of star center
Mode: Routed
Protocol: UDP
Compression: Disable
Digest: AUTO
Algorithm: Disable
Special order provider: Disable
Nethserver Tunnel Server Side (Star Center)
Connection: public address (There the public ip address of my star center)
Routes:
Local network: The local network of star center
Remote network: The remote local network
Topology: Subnet
VPN Network: The VPN address with sub
Protocol: UDP
Digest: AUTO
Algorithm: Disable
TLS: Auto
This is my configuration, i believe i have not configured something correctly.
Thanks in advance
Gen
@mastgen
Hi Gennaro
You can re-edit your OpenVPN in Cockpit… You will need to use the advanced box, and there set “Allow client to client connections”, as per screenshot above.
You can switch your language from Italian to English to make sure you get it all right, then switch back to italian… My NethServer doesn’t have the Italian language loaded - so I can provide german or english screenshots. As this Forum is english based, and the most help is possible in english, I’ll stick to english!
HI,
Try Firewall > Config > Permit traffic openvpn roadwariors openvpn tunnels and ipsec
Hi Andy, this is my screen configuration:
Client Tunnel Side:
Server Tunnel Side (Star Center):
Regards and thanks again!
I have activated this function on both client and server side but unfortunately nothing :frowning:
Strange, I’m only using the OpenVPN Roadwarrior Config, but I have the option to set “Client 2 Client” when editing…
You may need to erase the VPN config and recreate it anew. (Make a config backup first!).
Try create a 1 tunnel for client
Star Server => Client1
Star Server2 => Client2
And try ping ip of tunnel with tunnel
The network is set up with this type of configuration but strangely the clients tunnel between them there is no ping
this is the module of tunneling used to connect all locations:
3
OVPN RoadWarrior is not in use
Regards
Gen
Use Roadwarrior, then it works…
Hi Gennaro,
unless you’re connecting multiple networks (which is what tunnels are for), I suggest you use Roadwarrior and check that box that Andy told you. If you have to connect multiple networks, then you’ll need to push every subnet to every client in order to make them talk to each other.
Hi Roberto,
thanks for your response.
Tomorrow i will adopt this “cobweb” style method and i will update you.
Thanks again
Gen
Sadly this solution would have been the fastest and most ideal but for a matter of user “skills”, I had to opt for the tunnel :frowning: thanks again
it worked, I had to configure a tunnel server for each tunnel client as well, thank you so much!
Hi Gennaro,
glad I could be of help! NethServer can be a little bit tricky sometimes, but when you learn to master it, it becomes a very good all-rounder :grin:
