NethServer Version: NethServer release 7.8.2003 (final)
Module: OpenVPN
Dear Community,
I hope you are well and safe…
My problem:
Nethserver installed on a Proxmox Hypervisor with one NIC interface: 192.168.99.29/24
Router (Gateway) is performing a PAT for UDP traffic 7194 to 1194 (to Nethserver).
Note: no problems accessing Nethserver on the LAN.
When I setup OpenVPN (routed server) I was able to access Nethserver’s web interface and ping its NIC. But I couldn’t access or ping any other host on the LAN.
I added a static route on router pointing the OpenVPN network to the Nethserver’s NIC:
192.168.222.0/24 [1/0] via 192.168.99.29
With this route I can now ping all hosts on the network but… when I try to access any other host’s web interface or ssh I only got timeouts.
VPN client is running on a Windows 10 2004, OpenVPN connector V.3.2.2.(1455)
Please, could you help me? It looks like Nethserver is only allowing ICMP traffic from LAN hosts…
Thank you.
Kind regards,
J.
