Openvpn roard warrior explain
Ciao guys,
with basic knowledge of networks I wanted to rely on nethserver to configure my home network
Can you explain me what kind of network/address I need to configure to start openvpn roadwarrior?
On the online docs there isn’t lot detail in this field. (can be that i miss some knowledge)
if I try to use ip already used i got the error response.
immagine
Also if i use new network and submaski got “invalid network” error response
my network is so basic :slight_smile:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.254   0.0.0.0         UG    0      0        0 eno1
10.10.0.0       0.0.0.0         255.255.0.0     U     0      0        0 br0
172.17.0.0      0.0.0.0         255.255.0.0     U     0      0        0 docker0
172.18.0.0      0.0.0.0         255.255.0.0     U     0      0        0 br-0abf630b54db
172.19.0.0      0.0.0.0         255.255.0.0     U     0      0        0 br-806265c2737b
172.21.0.0      0.0.0.0         255.255.0.0     U     0      0        0 br-6662dd6eb688
172.28.0.0      0.0.0.0         255.255.0.0     U     0      0        0 aqua0
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 eno1
it should be a “stupid” problem but I haven’t come up with it for days :confused:
NethServer Version: 7.9.2009 (final)
Module: OpenVPN roadwarrior
10.10.10.10/16 isn’t a network address.
I’d use 192.168.191.0 with netmask 255.255.255.0.
Great… it working fine… but… can you kindly explain why it working?
or if you have some links that i can study on it :slight_smile:
it working fine also whit 10.10.1.0
Good that you show interest. Please google for ‘understanding ip networks’ and a huge amount of links will show and you can pick your choice from basic to advanced :slight_smile:
