hello,
I would like to understand how to set a password on a vpn (road warrior) user. Also, how to configure an OTP with a VPN user?
Thanks
Alain
hello,
Thanks
Alain
You can only use a password for a system user. If you create a VPN only user, then the only authentication available is certificate.
For OTP you need to setup 2FA, see the documentation for details.
