NethServer Version: 7.4.1708 (Final)
Module: OpenVPN RoadWarrior
Hello everyone.! o/
Already use OpenVPN in other “on-premises” installation and that lifted some needs…
So, when i trying to use NethServer for that JOB, because do it manually Sucks, and NethServer Rox.!!, just one need i can´t solved yet…!! and for that i need someone help, please.!! Sorry My Bad English too
I need to use the CCD for a specific user configuration…! “Push Route” and “Fixed IP”
Fixed IP = Solved using the NethServer reservation.! , no problem here.! works perfect.!
Push Route = i specific control what user can access through VPN specifying the Servers IP on push route inside the user ccd file…! , when i manually create the user file inside CCD it works, but it´s deleted after server restart, or by watchguard… no big deal to know by Who, lol… =D.
So, already look in Nethserver WEBUI but no success to find where i can add this specific routing pushs to user on WEBUI…!
I didin´t set VPN to be Default route when client connects.! And I Don´t whant that approach…!! I Just want to push a user´s specific route, like i do today on my other OpenVPN server.! , That way, my user can still access other network things without need to disconnect from VPN, and just the specifc access come through VPN tunnel.
Any Help, how can i edit a user ccd file without be deleted.!? no problem if WEBUI can´t do this right now.! , all the things Nethserver WEBUI do on OpenVPN is very nice and help a lot…!!
I Just has this problem to solve…!!
I´m appreciate the time dedicated to read this post, Thank you… And sorry my PT-BR English ;).
o/
Ozburn
