Show route print on your Windows!
Interface List
21…ac 7b a1 59 0c 62 …Dispositivo Bluetooth (Rede de área pessoal)
19…00 ff 7c a5 4c a1 …TAP-Windows Adapter V9
8…ac 7b a1 59 0c 5f …Adaptador Virtual Wi-Fi Direct da Microsoft
7…ae 7b a1 59 0c 5e …Adaptador Virtual de Rede Alojada da Microsof
3…ac 7b a1 59 0c 5e …Intel® Dual Band Wireless-N 7260
2…fc 15 b4 ec a4 f3 …Intel® Ethernet Connection I218-LM
1…Software Loopback Interface 1
5…00 00 00 00 00 00 00 e0 Placa Microsoft ISATAP
9…00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.175.1 192.168.175.13 25
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.175.0 255.255.255.0 On-link 192.168.175.13 281
192.168.175.13 255.255.255.255 On-link 192.168.175.13 281
192.168.175.255 255.255.255.255 On-link 192.168.175.13 281
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.175.13 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.175.13 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
9 306 ::/0 On-link
1 306 ::1/128 On-link
9 306 2001::/32 On-link
9 306 2001:0:9d38:6abd:2801:9fe:3f57:50f2/128
On-link
3 281 fe80::/64 On-link
9 306 fe80::/64 On-link
9 306 fe80::2801:9fe:3f57:50f2/128
On-link
3 281 fe80::494f:bab7:a2f4:24a8/128
On-link
1 306 ff00::/8 On-link
3 281 ff00::/8 On-link
9 306 ff00::/8 On-link
Persistent Routes:
None
Let connect to the openvpn
This is the correct route print
Interface List
IPv4 Route Table
Active Routes:
Persistent Routes:
None
IPv6 Route Table
Active Routes:
9 306 ::/0 On-link
On-link
On-link
On-link
Persistent Routes:
None
Oh man! You connect to VPN from network behind your router! It is wrong!
No I’m connecting from another network, a celular network.
The second route print is not correct also, does not have the vpn connection
Here is the third
Interface List
IPv4 Route Table
Active Routes:
Persistent Routes:
None
IPv6 Route Table
Active Routes:
9 306 ::/0 On-link
On-link
On-link
On-link
Persistent Routes:
None
Is server pushing routes to it clients?
You made a local ring so turn off OpenVPN ! Your windows ip 192.168.175.13 you try to connect to Openvpn 192.168.175.254, it should give your TAP adapter address 192.168.147.x and route table thought this ip !
Now is correct.
For some reason copy/paste was always the same thing
Yep so here are route with metric 20 to 192.168.175.0 192.168.147.9
And try to make tracert 192.168.175.253
One of reason that maybe 192.168.175.253 wouldnot be reachable is, on this test server you made def gateway 192.168.175.1 , change it to 192.168.175.254! And have a connection!
Let me try
Great it works!
Now only have the DNS problem
Dns the same! On your 192.168.175.254 do not use openDNS ip use 127.0.0.1 or input 192.168.175.254
Does not work.
For some reason the vpn server does not push the dns address to the client
Help on teamviewer is better and faster than writing on forum
From windows make nslookup host.home
Or edit your windows hosts file and add
192.168.175.253 viking.home
Show log of OpenVpN client
3 AM im going to bed
