Why both openvpn= with nothing and openvpn@host-to-net with something?
I went directly to /var/lib/nethserver/certs and removed all user certs (three residual .p12 not removed before), reset serial and certindex. I deleted and regenerated the user. Got this screen.
Went to the download and requested ovpn download and was told it was a zero length file:
Forget this path - I need my vpn access. Knowing that I had an old vpn (alpha2) file that did work, I copied and removed the keys/certificates like so:
I am familiar with using rpm at the command line. So removing the vpn package is not a problem.
Up to now, on nethserver, I have only been using the web interface to install (which I just love). In order to use the testing repository - it that something to do at the command line? If so, I can do so. I am familiar with both OpenSuSE and Ubuntu installs. From what I see in nethserver, it is more like Ubuntu, correct? Or do I just pull down the rpm and install?
On refreshing the dashboard, I noticed that the VPN tab was removed and on the navigation pane the VPN link disappeared. In its place I found OpenVPN links (one under Status and one under Gateway).
Going to the Gateway I reviewed the OpenVPN tab to make sure that the RoadWarrior settings were unchanged. They are still the same. I went to the Accounts tab, saw the kisaacs-r2 account and downloaded the opvn file. It looks good. I then replaced my hacked ovpn file with the one that I downloaded and
IT WORKED!!
Finally, I went to the Status OpenVPN page and got the following (my account is indeed active - but it indicates that OpenVPN server is disabled)
A simple question - regarding activating a new repository. I noticed a lot of new updates (see following screenshots). As I compared the version numbers all the way down, there seem to be a number of “discrepancies” between “version” and “release”. Since this is a production system, I need an explanation before I commit to performing the update. Basically am I “safe” to proceed - or is there the possibility that I could upset the great balance that I have?
I have a issue here, not anymore on Alpha, now beta stage
When i try to activate roadwarrior on OpenVPN the dashboard gives me:
Nethgui:
500 - Internal server error
1366796122+1325669847
When i try to initialize OpenVPN Service the following msg apears:
Oct 5 11:30:19 fwonline control-service: openvpn@host-to-net start
Oct 5 11:30:19 fwonline systemd: Starting OpenVPN Robust And Highly Flexible Tunneling Application On host/to/net…
Oct 5 11:30:20 fwonline openvpn[14501]: Options error: Unrecognized option or missing parameter(s) in host-to-net.conf:13: server (2.3.12)
Oct 5 11:30:20 fwonline openvpn[14501]: Use --help for more information.
Oct 5 11:30:20 fwonline systemd: openvpn@host-to-net.service: control process exited, code=exited status=1
Oct 5 11:30:20 fwonline systemd: Failed to start OpenVPN Robust And Highly Flexible Tunneling Application On host/to/net.
Oct 5 11:30:20 fwonline systemd: Unit openvpn@host-to-net.service entered failed state.
Oct 5 11:30:20 fwonline systemd: openvpn@host-to-net.service failed.
And i just saw another error on log:
Options error: --ifconfig-pool/–ifconfig-pool-persist requires --mode server
