xcod
(And)
1
NethServer Version: 7.2.1511 (rc1)
Module: OpenVPN, Static route
hi
i create static route in "Configuration - Static route"
it’s ok, work fine
i enable OpenVPN roadwarrior server and create accounts
its ok and work
but OpenVPN push my static route in "Configuration - Static route"
how it disable?
sorry my english
Thanks for asking xcod, hope that @harry @EddieA @Hunv might help here
giacomo
(Giacomo Sanchietti)
3
This is by design: clients on the remote network will be able to reach the configured routes.
If you want to disable it, you need to create a template custom for this fragment /etc/e-smith/templates/etc/openvpn/host-to-net.conf/40route
xcod
(And)
4
Hello!
thanks for the answer!
but I do not know programming language
can you help me, please?
Thank you!
giacomo
5
Not tested at all, but try this:
Create the template-custom dir:
mkdir -p /etc/e-smith/templates-custom/etc/openvpn/host-to-net.conf/
Copy the original fragment:
cp /etc/e-smith/templates/etc/openvpn/host-to-net.conf/40route /etc/e-smith/templates-custom/etc/openvpn/host-to-net.conf/40route
From the copied file, remove lines from 43 to 53.
Apply the config: signal-event nethserver-openvpn-update
xcod
(And)
6
Many thanks!
everything is working!
