Hello everyone! I have installed nethsecurity 8 with Openvpn server, the clients connect correctly and even ping the other IPs on the remote network, however I cannot access a specific remote samba server to share, however I can access other ports such as 9090. How do I release this access in nethsecurity? Should I release ports 138, 139 and 445 in nethsecurity?
NethServer Version: 8 23.05
Module: firewall
Hi @Rodrigo_Vieira_da_Co
If the 9090 server is a NethServer 7.x, you probably are missing the trusted networks for the IP of the OpenVPN network…
Just add it in, and it should allow access to samba.
Thanks for your help, Andy! That’s exactly what it was!
The old samba server I have nethserver 7.9, and its firewall pointed me to the error in the log regarding the vpn network:
Mar 18 08:40:01 p2samba kernel: Shorewall:net2fw:DROP:IN=enp2s0 OUT= MAC=3c:7c:3f:10:aa:d0:bc:24:11:26:c9:30:08:00 SRC=192.168. 23.10 DST=192.168.2.15 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=27565 DF PROTO=TCP SPT=57817 DPT=445 WINDOW=65535 RES=0x00 SYN URGP=0
I included the new vpn range in the shorewall of the old nethserver like trusted and now I have access to samba!
Thanks for your help!
