funky
(Max Feldflieger)
1
Hello, I hope someone can help me.
How can I open a port on the Nethserver (10050 for Zabbix Agent passive) for a Zabbix Server in the same Class-C network?
The zabbix agent runs and listens on port 10050 but scanned with zenmap sees the port closed.
Many greetings, Max
funky
(Max Feldflieger)
2
Found the solution to my problem here:
Thanks
Hi Max,
I made some documentation on Zabbix, it’s in French but the commands are all the same, also Google Translate is your friend.
https://www.micronator.org/affaires/?s=zabbix&post_type=product.
Michel-André
