I replaced Collabora with Onlyoffice to work within Nextcloud. Everything looks fine. I can reach the documentserver. But when I try to open a document in Nextcloud, I get “Onlyoffice is temporarily not available. Contact your administrator.”
Can anybody tell what triggers this error message and where to look for the reason?
Have you consulted this section?
https://wiki.nethserver.org/doku.php?id=onlyoffice#something_s_not_working
Moin Ralf,
Which version of Onlyoffice do you use?
Note this: onlyoffice [NethServer Wiki]
Regards
Uwe
Does the current version of Onlyoffice work now, or do you still have to stay with the old one?
You still have use the 7.1 version, I’ll update the wiki page as soon as I got more recent versions of Onlyoffice working.
It works now. Maybe it was a firewall and address problem.
After configuring Haproxy on pfSense as proxy to onlyoffice port 8082 I could connect.
It’s the Onlyoffice version offered by the NS software center.
Hi @mrmarkuz,
Is there currently a possibility to use a newer version of Onlyoffice than the 7.1.1?
Regards…
Uwe
Sorry, not yet but I’m working on it…
