OnlyOffice problem
NethServer Version: 7.7.1908
Module: OnlyOffice, NextCloud, WebTop
I’m trying to set up a document server with OnlyOffice. I installed the module, but when I try to modify the Document Edit Server address I’m getting this error: Error when trying to connect (Error occurred in the document service: Error while downloading the document file to be converted.)
If I try to open a document into WebTop or NextCloud I can see these logs:
2019/12/05 16:40:55 [error] 21825#0: *13 connect() failed (111: Connection refused) while connecting to upstream, client: 10.100.100.187, server: , request: "GET /5.4.2-46//spellchecker/doc/c5cc48342ec42d72b955/c/info?t=1575560454904 HTTP/1.1", upstream: "http://127.0.0.1:48080/doc/c5cc48342ec42d72b955/c/info", host: "mail.quality-group.eu:8082", referrer: "https://mail.domain.eu:8082/5.4.2-46//web-apps/apps/spreadsheeteditor/main/index.html?_dc=5.4.2-46&lang=it_IT&customer=ONLYOFFICE&frameEditorId=ext-comp-1210-deplaceholder"
/cc @mrmarkuz
Do you mean the host property?
config setprop fw_onlyoffice host example.com
Do you see the onlyoffice welcome page at yourdomain.com:8082 ?
Maybe restarting the services helps, see WebTop + OnlyOffice - #5 by KdB
