OnlyOffice Mobile devices
NethServer Version: 7.6
Module: OnlyOffice / latest Version NextCloud
Hello
I am confused, from my Desktop (W7P64) Onlyoffice open up dokuments in Firefox, Chrome (never try Explorer).
When I am using my Samsung 7edge, the Webside said “Dokument Server is not running”.
The smartphone is via WLAN in the same network, and privat Nextcloud is running.
any Idea ?
THX
Which browser are you using on your cell phone?
Firefox and Chrome
Is this WLAN added as a trusted network in server manager?
It is the same network @home
Can you reach the documentserver page (https://nethserver:8082) from the mobile phone browser? You may have to allow it if you don’t use a valid certificate.
https://wiki.nethserver.org/doku.php?id=onlyoffice#set_host_domain
Hello Markus
That was the solution. I had to open up the side https://nethserver:8082 and there is 2 add the certificate too. Only accept and add the certificate on nextcloud side https://nethserver/nextcloud is not enough.
Now its running with VPN to (fritzbx 7590 and IPsec on the box!)
THX
