Onlyoffice blank page
System version
NethServer release 7.4.1708 (Final)
Kernel release
3.10.0-693.21.1.el7.x86_64
I’m looking for it, but I can not find the solution.
I installed it without error. If you are open a document, only a blank page will come up.
I’ve been looking for the solution for two days now :slight_smile:
If you can, help me out.
Thanks
with wich web browser?
Have you visited the document server page (https://fqdn:8082)?
this is what I see
does it work accessing nextcloud through the fqdn instead of the IP?
the FQDN also works
Any warning or error in nextcloud.log?
solved.
I have given different addresses.
the outside and then the inside.
Now good:
