I had to make a change to my network recently. In doing so I had to move my NS8 to a new ip. I had to switch the AD/Samba ip via terminal. All seems ok except - I am not longer able to send email from mail server / Webtop. Note I can recieve emails just fine.
When I made the move I did notice that the notifications (4 to 5 at the same time are on going). They offer no description on what it is just a circle with and i (can not click on circle with i to give info). Of course just after notification completes then another one starts. It leaves a Completed notification - which also has no description to tell you what completed.
At the top it has a continuous circle animated circling. Not sure what to do on this as there is no description to what is happening. I would be incline to think it has something to do with mail server / Webmail as I am not able to send out. But that is just a guess of course.
Check if something pops-out on cluster log.
Monitor top or similar utilities for activity.
use lsof to see what files are being used… as a way to pinpoint where to look at.
Thanks @dnutan for the quick reply and thanks for the link so I can look at the feedback.
Note - I didn’t put in the AD/Samba ip change via terminal till after I saw the on going notifications and completed notifies… So I don’t think it was that…
I am going to check the logs and such…
Much appreciated. I will check it out. and see if it relates in some way to what I am seeing.
