NethServer Version: 7.9.2009
Module: Old WebInterface
Hi All,
I am not able to see old interface in new NS distro 7.9.2009. ONly 9090 cockpit is available. Please help to find old web-interface because i am much familiar with that.
Hi All,
Didnt you read the release notes into announcement? NethGUI (old interface, as you writing) is no longer installed as default package, you have to install it manually.
Anyway i suggest you to get familiar with cockpit.
can you tell me the package name? because i didn’t find in software center. Thanks
@dev_team
Is it missing?
I confirm there’s an issue here. Thank you for reporting it, I’m working to fix it!
As workaround run the command
yum install nethserver-httpd-admin
There was a stale YUM groups definitions. Now it is fixed and in a few hours it will be synchronized to all mirrors.
This is the fixed file http://packages.nethserver.org/nethserver/7.9.2009/updates/x86_64/repodata/1d727d3ab5f44021d9f5afcab203b4ef13055493dc4b35eb6307e33440f1f9e9-updates-groups.x86_64.xml
You can see the “Old server manager” group definition inside.
Again, thank you @Hitesh_Dubey for reporting it!
