Few days ago we released a recompiled version of Network UPS Tools (NUT) to workaround an upstream bug.
Previously released NUT packages were:
- nut-2.7.4-17.ns7.x86_64.rpm
- nut-cgi-2.7.4-17.ns7.x86_64.rpm
- nut-client-2.7.4-17.ns7.x86_64.rpm
- nut-debuginfo-2.7.4-17.ns7.x86_64.rpm
- nut-devel-2.7.4-17.ns7.x86_64.rpm
- nut-xml-2.7.4-17.ns7.x86_64.rpm
Such RPMs have been now removed from NethServer base update.
The bug is now fixed in EPEL, but I wrongly recompiled a version which is newer than the upstream one, thus we can’t simply install from EPEL.
(Lesson learnt: never recompile an upstream package!)
You could encounter the following YUM errors:
Error: Package: nut-2.7.4-17.ns7.x86_64 (installed)
Requires: libipmimonitoring.so.5()(64bit)
Removing: freeipmi-1.2.9-8.el7.x86_64 (@nh-base)
Updated By: freeipmi-1.5.7-2.el7.x86_64 (nh-base)
~libipmimonitoring.so.6()(64bit)
Requires: libfreeipmi.so.13()(64bit)
~libfreeipmi.so.17()(64bit)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
or
Failed to check for updates with the following error message:
Failed to build transaction: nut-2.7.4-17.ns7.x86_64 requires libfreeipmi.so.13()(64bit)
nut-2.7.4-17.ns7.x86_64 requires libipmimonitoring.so.5()(64bit)
Solution
Remove the old nut package and install the upstream one:
rpm -e nut-2.7.4-17.ns7.x86_64 nut-client-2.7.4-17.ns7.x86_64 --nodeps
yum --disablerepo=* --enablerepo=base,updates,epel install nut
signal-event nethserver-nut-save
I apologize for the inconvenient.
